Any way to use MORE screen?
- Feedback
- Community Site Feedback
- Any way to use MORE screen?
08-04-2016 10:52 AM
This new layout is only using about 60% of my screen width, loads of waste space, from the EXCESS white space between the boxes and all over.
There doesn't seem to be any way of increasing the useage?
I am NOT on a mobile device why do I have to see a mobile layout?
Re: Any way to use MORE screen?
08-04-2016 11:02 AM
Actually the width restriction was also on the old Forums
The problem isn't the width it is the appalling waste of vertical space which I have complained about at length during the beta phase. It was improved so you can guess how bad it was before
My particular bête noire is the unread topics page where it is totally useless without a load of scrolling - this morning there were 5 pages of it
Note that to reduce the space taken up by posts I have hidden the sigs
08-04-2016 11:04 AM - edited 08-04-2016 11:05 AM
Deleted - it looks as though it duplicated because it was posted in the middle of a software upgrade
08-04-2016 11:26 AM
Why do we need a reply on EACH post? a quote button would be better.
08-04-2016 1:06 PM
The Reply button should specifically alert that poster of a reply even when not quoted - that's not always needed - assuming they're setup for notifications - as well as anyone else subscribed to the thread. But the amount of space occupied by all of this things has been raised, some of it is down to corporate styling policy - I remarked about this in another thread - go and look at the main site, that's just as bad. Other aspects are that the size of some buttons on Mobile devices need to be considered, but there are also some HUGE ones that need to be scaled down. The idea of a floating Reply button has also been considered, but that's a bigger coding issue I believe
There are also a number of features missing that we are pressing for.
08-04-2016 1:37 PM
A quick and dirty fix in my opinion would simply to have the thread title area(s) shaded in with a very light grey or very off white. This in itself would reduce the white space.
The icon size could also be generally reduced by a couple of pixels in height too, although that'd take a bit longer.
08-04-2016 1:41 PM
It's been suggested that the titles be removed from replies, or at the very least the font size reduced significantly. Reducing a few pixels here and there is relatively trivial as I understand it, but as mentioned before it's being driven by corporate styling policy at this time - but that may change ![]()
