Ambiguous notifications count
Fixes: 251
@James_B
For a couple of weeks I’ve been seeing inconsistent new notification counts.  In the “space” of taking some down time, I’ve not looked at my notifications page for 2+ weeks.
Upon logging in I see 101 new notifications reported.
Subsequent to making a post, circa 50 notifications are then reported.
If I allow the session to time out and I login again I see 100+.  I see different experiences on other devices.  The experience is reproducible.
We have seen similar over the years - it is as though the service supplier has several service instances … which they are not keeping in sync.  Thus depending on which instance of the service services the connection, the user experience is inconsistent.  I will try to refrain from accessing the notification screen so that the supplier can inspect the case.
90 REPLIES 90
Fixes: 251
Re: Ambiguous notifications count
Now that I can get in with the correct CSS rendering...
Notification Count on LoginNotification Count on Login
Notification Count after having made a postNotification Count after having made a post
James_B
Fixes: 19
That's an odd one, @Townman
I'll raise it with Khoros.
Thanks for flagging.
James
Fixes: 251
@James_B
Any news please?
I suspect something supplemental in play here.  The notification counts are now 101 / 77.  Some increase in the notifications count is to be expected given replies to my subscribed threads, however the higher number is not increasing.
James_B
Fixes: 19
Hi @Townman,
Khoros have asked - When the superuser views their notification feed (clicks on the counter), does the count reset to zero as expected, or does it remain at an elevated number?
James
Fixes: 251
@James_B
So the they can investigate I have not done anything which might reset the count (trash the evidence).
I cannot discern what gives rise to seeing one number or the other.  Having ‘switched’ to the lower figure being reported, it sticks with that until whenever.  I suspect that there is a timeout somewhere.
Note I have multiple devices accessing the account some of which have “stayed logged in” set.
I am posting this from my phone which does not have stay logged in set.  At the moment I see a count of 101.  I have seen 102.
i expect that after posting this I will see the lower number.  Whilst the lower number is rising (as is to be expected as I’m not ‘servicing’ notifications) the higher number is not, suggesting that source of reporting has an upper limit.
Surely the supplier can run a data query against my account to see what the number should be?  My estimate would be 150.  Count by type might be a useful diagnostic.
edit: expectations fulfilled - count now reported as 78.
edit: now 77 … some thing does not add up!
Fixes: 251
@James_B
Any update please?
Here are more observations on the oddities...
  1. The higher count changes to the lower count following a post to a thread
  2. It does not change on sending a PM
  3. It sticks at 101 unless I receive a PM, which does increment it ... and it decrements after reading the PM
  4. The lower count reverts to the higher count after some indeterminate period which appears to be less than the logout period ... though that could be muddled by having multiple concurrent sessions on different devices
  5. The lower count varies up and down as I look at various threads, possibly as though looking at a thread for which there is a notification changes the notification count - this is not something I have observed before; I thought notification counts were not adjusted until the notification page is accessed (which I am still avoiding doing)
Fixes: 251
@James_B
Is a meaningful response from the supplier a likely outcome here … or do I park this as another characteristic of this flaky product and just move on?
James_B
Fixes: 19
Hi @Townman,
I haven't had any further updates yet but I'll keep you in the loop. Hopefully it's a straightforward fix.
James
Fixes: 251
@James_B
Would you know if someone is investigating this ... or is this a different characteristic of the same gremlins.
I little earlier I sawn NO NOTIFICATIONS being reported on my mobile following having seen 101 reported.  I became miffed fearing that some bright spark might have thought that the "solution" here is to clear the counter 'for me' ... something I could do myself (rather than retain the account status for investigation.
However a little later a count of 50 was returned, though that is somewhat lower than the previous lower number.  Still no not happy, but better than all of the notifications being vapourised.
Back on my laptop, I again see 101...
Until I make a post...
Something weird is happening, but its not wonderful.
What has the vendor done to investigate the matter?
What are my unread notification counts by type?  I suspect that some scenario shows the count of everything. whilst elsewhere is showing a sub-set count.
Is there a count ceiling in the system?  The higher count has never exceeded 101 unless I have unread PMs; that reported count is 101 + number of unread PMs.
Has there been any changes to the notification logic?  It issued to be the case that the notification count was not adjusted until visiting the notifications page, at which point it was set to zero.  Now it appears that visiting a post which is 'notified' causes the notification count to reduce even though the notification page has not been visited.
James_B
Fixes: 19
There aren't any updates on the ticket yet to say they've attempted any changes yet.
Thanks for your latest observations, I've added to the ticket.
James
Fixes: 251
@James_B
Any news please?
Is the vendor actually doing anything or is it much like so many issues around this technology stack - either they cannot be bothered (no interest) or they just do not have the skill or capacity to investigate and remedy the broken experience encountered by their user base?
Not touching the notifications page to maintain the error conditions is not overly convenient but I’m not disposed to destroy the broken / evidential state if the can be bothered to take a proper look at the situation.  Gathering of data state and diagnostic traces would seem appropriate if they have a real interest in investigating the reported issue.  It’s been with them weeks now.
James_B
Fixes: 19
Hi @Townman,
It's a lower priority ticket but it will be looked at - I've chased this morning.
I wouldn't worry about maintaining the broken state in the meantime (they'll be able to view historic logs) - I'd also be interested to see if clearing your notifications resolves it since you're the only reporter.
James
Fixes: 251
Being the only reporter is why I’m maintaining the broken state.  I’ve seen more than enough fringe cases in my years which when examined explain a host of mysterious issues.  I would not want a “cannot reproduce the issue” outcome from this arsing from not capturing the evidence whilst it’s reproducible.
There are several issues here …
  1. There are two counts being reported 101 and something else
  2. 101 appears to be a ceiling for post notifications
  3. Having unread PMs adds to the reported ceiling
  4. Making a post causes the lower count to be reported
  5. After an indeterminate time period or event 101 is again reported
  6. Haphazardly reading a thread which is associated with a waiting notification appears to decrease the lower figure implying some process other than looking at the notification page modifies the notification count - thus appears to be new functionality and could be the source of this experience
It is possible that I’m the only reporter due to the way I’m using the service at present.  Normally I use the. Notifications List as my priority follow up stuff … which I’m not doing at the moment as I’m busy with other stuff.  Therefore I’ve not been clearing the notifications count and am probably exposing untested scenarios.
Until someone (at least) gathers the current evidence they do not know what they are looking at - a blip aberration or a rats’ nest of bugs.
Fixes: 251
Now that’s odd - given the above took time to type, after posting the count was 101 suggesting there’s a timeout factor in here too.
