A question about Mod reported Spam
Fixes: 251
Re: A question about Mod reported Spam
@Anonymous - the concept would not indicate a post had been reported, unless one sought to report it (again).
@Mav & @Strat - does the number of reports on non-spam posts influence the thought process over if a post needs moderation?
@Townman - Which is why I said "should they care to look". You can look at reporting a post without actually reporting it.
jaread83
Fixes: 81
Hopefully it will lessen the amount of repeated reports but at the same time, possibly not. A lot of users ignore my 'this is an old thread' warning on topics with the last reply being over 120 days old... we shall see Smiley
Mav
Fixes: 518
On a good day we're able to identify and remove spammers before they even make their first post.
As @jaread83 mentioned this recent PM spamming was borne out of a Lithium issue with the ranking system so, hopefully, once fixed, such spamming will be reduced to zero once more.
Forum Moderator and Customer
Fixes: 1,495
Nope, every report is read, potentially discussed and action taken if deemed necessary
