Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
12-03-2013 11:55 AM
I think this be a waste of time we all know there a problem on plus net side. As it evenings when I use FaceTime.
12-03-2013 12:02 PM
Quote from: Kelly The more general speed issues aren't reproducible yet. There is no common piece of kit/location which appears to be causing it. It could be related to the original problem, i.e. all traffic goes through the devices that need to be patched, but this problem is more difficult to diagnose.
Thanks for the straightforward answer. I appreciate problems can sometimes be very difficult to diagnose (having spent 30 years trouble-shooting networks!).
Quote from: Kelly If BT were having some contention issues at the same time, it could be clouding the water though 😕
Would I be right in assuming that contention in the BTW network could be diagnosed by getting someone suffering the problem to ping their Plusnet gateway? This is the first node the connection hits at the other end of the BTW VLAN. If a customer gets 200ms pings to bbc.co.uk and 180ms pings to the gateway, then it would be safe to assume there's a lot of latency over the VLAN, unless the gateway router itself is congested and slow to respond. Currently I'm getting slightly variable pings to my gateway (ptn-ag04), not sure why that would be:
Quote --- 195.166.128.193 ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 7.024/11.152/25.433/6.418 ms
Quote from: rookey I am told it the upload speed that causing the problem and high ping too. This where the problem is
I would expect high latency to cause havoc with a Facetime call, so I suspect that's where the main problem lies.
12-03-2013 12:05 PM
As this what been happening recently and that why FaceTime been an arse for a month cos of this problem. Never had problems before and not being able talk to my families is a let down
That the letters all ready to be posted to watch dog, trading standard a d ofcom
12-03-2013 12:09 PM
I tried pinging my gateway (ptw-ag02) and get this:
Quote Ping statistics for 195.166.128.196:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 5ms, Maximum = 550ms, Average = 20ms
If I ping bbc.co.uk, I get this:
Quote Ping statistics for 212.58.251.195:
Minimum = 3ms, Maximum = 5ms, Average = 4ms
12-03-2013 12:13 PM
Quote from: rookey Is there a version for mac?
I think you'd need to be running both Facetime and Wireshark on your Mac. Not sure if you have the Mac version of Facetime installed. Mac version of Wireshark can be found here.
12-03-2013 12:21 PM
Hmmm... that won't work then! Obviously the same issue with traceroute:
Quote traceroute to bbc.co.uk (212.58.251.195), 64 hops max, 52 byte packets
1 192.168.68.1 (192.168.68.1) 0.383 ms 0.282 ms 0.227 ms
2 lo0-central10.ptn-ag04.plus.net (195.166.128.193) 8.539 ms 15.181 ms 24.914 ms
3 link10-central10.ptn-gw02.plus.net (84.93.248.242) 6.528 ms 6.607 ms 6.801 ms
etc
Responding to pings is just a very low priority task on the gateway router...?
12-03-2013 12:24 PM
12-03-2013 12:25 PM
12-03-2013 12:28 PM
adie:red CSA name removed as per link:rules
12-03-2013 12:38 PM
Edit: I know you are upset, but upsetting some of the most helpful members of the PN team won't help either.
12-03-2013 12:43 PM
No I am not upsetting anyone Plus net is upsetting me so why we not allowed to upset them. That not right is it...
It seems no one knows anything in plus net everything goes round in a circle. My ticket clearly stated what I was suggesting and to raise a fault is totally stupid answer.
12-03-2013 12:46 PM
12-03-2013 12:47 PM
here the thred
http://community.plus.net/forum/index.php/topic,112768.0.html
12-03-2013 12:53 PM
Quote from: rookey I was just looking at this forum and emails that all i have done all morning...
You do seem to have a lot of high latency peaks (the yellow part of the graph) for just forum browsing and email. As AndyH suggests, it might be worth keeping that stuff in your thread over here, as there may well be something else going on...
Edit: You beat me to it
12-03-2013 12:59 PM
