Peak time latency spikes
Jaggies
Re: Peak time latency spikes
Agreed - it's likely to be a Flash issue. Pinging from a command prompt and getting a good result largely rules out security software issues. You could try a pathping as well - here's mine:
C:\Users\Brian>pathping bbc.co.uk
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
 0  AriesPC.home [192.168.1.65]
 1  BThomehub.home [192.168.1.254]
 2  lo0-central10.pcl-ag08.plus.net [195.166.128.189]
 3  link10-central10.pcl-gw02.plus.net [84.93.249.242]
 4  xe-2-2-0.pcl-cr02.plus.net [212.159.1.14]
 5  ae2.pcl-cr01.plus.net [195.166.129.6]
 6  ae1.ptw-cr01.plus.net [195.166.129.0]
 7  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
 8     *        *        *
Computing statistics for 175 seconds...
           Source to Here   This Node/Link
Hop  RTT    Lost/Sent = Pct  Lost/Sent = Pct  Address
                               0/ 100 =  0%   |
 1    1ms     0/ 100 =  0%     0/ 100 =  0%  BThomehub.home [192.168.1.254]
                               1/ 100 =  1%   |
 2   57ms     1/ 100 =  1%     0/ 100 =  0%  lo0-central10.pcl-ag08.plus.net [195.166.128.189]
                               0/ 100 =  0%   |
 3   54ms     3/ 100 =  3%     2/ 100 =  2%  link10-central10.pcl-gw02.plus.net [84.93.249.242]
                               0/ 100 =  0%   |
 4   54ms     2/ 100 =  2%     1/ 100 =  1%  xe-2-2-0.pcl-cr02.plus.net [212.159.1.14]
                               0/ 100 =  0%   |
 5   53ms     1/ 100 =  1%     0/ 100 =  0%  ae2.pcl-cr01.plus.net [195.166.129.6]
                               0/ 100 =  0%   |
 6   53ms     2/ 100 =  2%     1/ 100 =  1%  ae1.ptw-cr01.plus.net [195.166.129.0]
                               0/ 100 =  0%   |
 7   50ms     1/ 100 =  1%     0/ 100 =  0%  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
Trace complete.
(Edit- typo)
chuckster
Just had to disconnect as speed dropped down so far the net was practically unusable.  Was on ptn-ago3 Telehouse North
Just had to chuckle.. forgot I did a speedtest before disconnecting.  22Mb/s too slow.. hahaha.  But seriously, pages did start to timeout.
Reconnected and back at max speed - now on pcl-ag04 City Lifeline House
More like it.
chrispurvey
If anybody has any buffering/gaming issues or slow speeds would you be able to capture a <a href="http://community.plus.net/library/faults/using-wireshark-for-data-capture/">wireshark</a> so we can look at the data?
walterhornby
I'm having download problems with ptw-ag02. nothing major ping of 42, and download speed of 4.95
cihan
Quote from: Bright
@cihan
Log into the management page of the router. Under "Broadband Connection" click the Disconnect button. Then click "Connect" to re-connect. Which gateway you end up on is a bit of a lottery, but you can check your gateway here.
EDIT: corrected typo
Thanks for the help! New gateway seems to have helped load pages quicker, but anything like Youtube it still out of the question, I just can't stream anything at all.
WendyDavies
Im able to use YouTube now and my ping seems to be going back to normal just not showing up on speedtests. Like others have said it could be related on my end so case closed on that one. Switching to ptw-ag03 helped.
@Jaggies and Bright: Thanks for your help. If i do see the QoS dip then ill try what you have recommended.
kmilburn
I've been experiencing problems this evening,  getting 5-10mbps about half an hour ago,  up to 20mbps now,  from a usual 75mbps.
Chris,  I've got a wireshark trace from around 22:00,   but it's 8.7MiB compressed.
What should I do with it?
Edit:  gateway is pcl-ag04
benbooafrica
New to the forum. We have been experiencing delays/latency problems for the past few weeks but only tonight raised a ticket to Plusnet suspecting the problem maybe related to interleaving being switched on our line and asking Plusnet to switch it off to see if it helps, only after that did I realise there is a multitude of posts on the forum and realised it was a more widespread problem, maybe gateway related. We are connected to gateway ptn-ag02 which is not mentioned in earlier posts so rule that out for the moment but carrying out a ping test during the period we experience the delay we get an average of 152ms other readings 61ms and 22ms.
To Chris Purvey, I took a wireshark trace during the period we experienced the delay and as it cleared on it's own, would you like to see it?
Rgds
benbooafrica
austinsom
Been a little slower this evening, although I haven't been on the computer alot tonight.
Still connected to pcl-ag06.
Ping and jitter as of 5 minutes ago not so good:
Although speedtest seemed ok:
TBB graph is still showing increased latency at peak times, although this is not as severe with less big spikes than it was last night:
chrispurvey
Quote from: kmilburn
Quote from: benbooafrica
I'll arrange to get this data from you. Thank you for capturing this.
MsDizzie
Still looking good for me on ptn-ag04
http://speedtest.net/result/2558196097.png
Fixes: 1,491
mine went a bit all weird yesterday:
timpncom
Currently on pcl-ag03 and download speed is awful! Normally get 25-30Mb but now seems throttled at around 3Mb.
http://www.speedtest.net/result/2559093806.png
Before I reconnected I was on ptw-ag04 which seemed a bit better and would sometimes give full speed download speedtest and other times not. In fact quite often when doing speedtest I'd see it downloading at full speed ~30Mb for a few seconds then suddenly drop to around 3Mb and remain there for rest of the download. Upload has always been unaffected.
$ ping ntp.plus.net
Pinging ntp.plus.net [212.159.6.10] with 32 bytes of data:
Reply from 212.159.6.10: bytes=32 time=229ms TTL=250
Reply from 212.159.6.10: bytes=32 time=203ms TTL=250
Reply from 212.159.6.10: bytes=32 time=397ms TTL=250
Reply from 212.159.6.10: bytes=32 time=604ms TTL=250
Ping statistics for 212.159.6.10:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 203ms, Maximum = 604ms, Average = 358ms
Then a few mins later faster ping but still slow speedtests.
$ ping ntp.plus.net
Reply from 212.159.6.10: bytes=32 time=27ms TTL=250
Reply from 212.159.6.10: bytes=32 time=21ms TTL=250
   Minimum = 21ms, Maximum = 27ms, Average = 22ms
$ pathping ntp.plus.net -q 50
Tracing route to ntp.plus.net [212.159.6.10]
 0  tim-laptop.lan [192.168.1.64]
 1  dsldevice.lan [192.168.1.254]
 2  lo0-central10.pcl-ag06.plus.net [195.166.128.187]
 3  link7-central10.pcl-gw01.plus.net [84.93.249.172]
 4  176.core.access.plus.net [212.159.0.176]
 5  po2.pcl-gw01.plus.net [195.166.129.41]
 6  vl63.pcl-lb01.plus.net [212.159.2.252]
 7  cdns02.plus.net [212.159.6.10]
Computing statistics for 87 seconds...
                               0/  50 =  0%   |
 1    1ms     0/  50 =  0%     0/  50 =  0%  dsldevice.lan [192.168.1.254]
                               0/  50 =  0%   |
 2   24ms     0/  50 =  0%     0/  50 =  0%  lo0-central10.pcl-ag06.plus.net [195.166.128.187]
                               0/  50 =  0%   |
 3   22ms     0/  50 =  0%     0/  50 =  0%  link7-central10.pcl-gw01.plus.net[84.93.249.172]
                               0/  50 =  0%   |
 4   23ms     0/  50 =  0%     0/  50 =  0%  176.core.access.plus.net [212.159.0.176]
                               0/  50 =  0%   |
 5   22ms     0/  50 =  0%     0/  50 =  0%  po2.pcl-gw01.plus.net [195.166.129.41]
                               0/  50 =  0%   |
 6   21ms     0/  50 =  0%     0/  50 =  0%  vl63.pcl-lb01.plus.net [212.159.2.252]
                               0/  50 =  0%   |
 7   22ms     0/  50 =  0%     0/  50 =  0%  cdns02.plus.net [212.159.6.10]
Trace complete.
Edit, was just about to reconnect but just done another speedtest and now it's the fastest download I've ever had!!
http://www.speedtest.net/result/2559113185.png
Regards,
Tim
cihan
Quote from: cihan
Quote from: Bright
@cihan
I've tried another socket but still no change. Web pages are ok, but streaming is out of the question. Think I'm barely reaching 1MB in download speed.
I tried installing a TP-Link router but gave up, its like trying to decipher hieroglyphics. Got my Windows laptop to recognise it, good signal, but just couldn't get a Net connection. Argh! I don't think my net woes are due to the Netgear that originally came with the Plusnet deal anyway.
EDIT: Also a question, can anyone tell me what my download speed is supposed to be? I originally signed up for Plusnet Extra years ago. Honestly it feels like my speed has never gone past 2 or 3MB, is that what I'm supposed to be getting?
EDIT EDIT: Also, seems the closest exchange is showing amber for VP, might have something to do with my speed problem lately?
http://usertools.plus.net/exchanges/?exchange=Catford&exact=200&plugin=vp
FINAL EDIT!: I've noticed a BT guy fiddling with cables on my road the last couple days, he's not around but a barrier is set up near a pole, another possible cause...?
KevinG
Quote from: cihan
Put your phone number in here and that will tell you what you are supposed to be getting.
