Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
27-02-2013 9:11 PM
27-02-2013 9:15 PM
27-02-2013 9:16 PM
On gateway ptw-ag04.
$ traceroute bbc.co.uk
traceroute to bbc.co.uk (212.58.241.131), 30 hops max, 60 byte packets
1 dsldevice.lan (192.168.1.254) 56.892 ms 56.802 ms 56.758 ms
2 lo0-central10.ptw-ag04.plus.net (195.166.128.194) 29.984 ms 29.967 ms 29.947 ms
3 link14-central10.ptw-gw02.plus.net (84.93.248.122) 29.866 ms 29.861 ms 29.850 ms
4 xe-10-0-0.ptw-cr02.plus.net (212.159.1.42) 29.742 ms 29.754 ms 29.753 ms
5 ae2.ptw-cr01.plus.net (195.166.129.4) 51.106 ms 51.056 ms 51.041 ms
6 kingston-gw.thdo.bbc.co.uk (212.58.239.6) 29.610 ms 21.890 ms 21.858 ms
7 * * *
8 ae1.er01.rbsov.bbc.co.uk (132.185.254.46) 26.379 ms 26.314 ms 26.366 ms
9 132.185.255.60 (132.185.255.60) 29.116 ms 29.125 ms 24.477 ms
10 virtual-vip.thdo.bbc.co.uk (212.58.241.131) 24.378 ms 24.381 ms 23.805 ms
All seems fine, except for that bolded route, which is slower than the rest (dsldevice.lan always swings between 50-90ms without any ill effects).
27-02-2013 9:20 PM
Quote from: Anotherone @austinsom
The TBB graph you linked shows a stable minimum latency circa 40ms. Your recent ping test shows 21ms. Such a big change from a gateway hop is unusual.
If the line was previously NOT interleaved and showing pings of 21ms, it says here that a fault ticket has been raised - which I believe automatically switches interleaving ON, which would explain the step change in ping times.
27-02-2013 9:22 PM
27-02-2013 9:25 PM
Quote from: Joopzor ag04 seems like a good one atm
If you're referring to pcl-ag04, that's the one I finally settled on, not 100% but a lot better than the others I have seen in the last half an hour or so.
27-02-2013 9:29 PM
@purleigh, no, it was his ping test just now after he hopped gateway that gave 21ms. I thought the same as you until I saw his latest post just before I posted, that's why I'm keen to see a recent TBB
27-02-2013 9:30 PM
27-02-2013 9:33 PM
27-02-2013 9:37 PM
27-02-2013 9:41 PM
I'm sure interleaving was on as on my router after I joined PN it always said interleaved path - is that the same?
27-02-2013 9:41 PM
27-02-2013 9:54 PM
27-02-2013 9:59 PM
Seems like we are just keep posting low speeds, high pings etc.... for days on end, but nothing is improving.
What are PN actively doing (apart from collecting data) to resolve this and is there any rough time scale for a fix ?
Regards
Mike
27-02-2013 9:59 PM
