Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
27-02-2013 10:03 PM
Does the gateway switching thing show where the problem lies?
I still remain unaffected and my speed tests are constantly around 80-90Mbps on all gateways.
27-02-2013 10:13 PM
Ex-Plusnet Jobsbody
27-02-2013 10:17 PM
27-02-2013 10:29 PM
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/0cde42ce765489e8a0e9ad1cfb267aeb.html"><img alt="My Broadband Ping - austinsom" src="http://www.thinkbroadband.com/ping/share-thumb/0cde42ce765489e8a0e9ad1cfb267aeb.png" /></a>
I'll post another shot later, but so far not impressed, as none of this should be necessary.
27-02-2013 10:42 PM
FAQ
1. Best Effort Test: -provides background information.
Download Speed
55.94 Mbps
0 Mbps 67.62 Mbps
Max Achievable Speed
Download speedachieved during the test was - 55.94 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-67.62 Mbps .
Additional Information:
IP Profile for your line is - 67.62 Mbps
Upload Speed
10.73 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 10.73Mbps
Traceroute for this evening .
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.244.69]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.1.1
2 35 ms 27 ms 15 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182
3 15 ms 15 ms 15 ms link11-central10.pcl-gw01.plus.net [84.93.249.20
4 15 ms 14 ms 15 ms xe-0-2-0.pcl-cr01.plus.net [212.159.1.0]
5 15 ms 15 ms 15 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 49 ms 15 ms 15 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 * * * Request timed out.
9 15 ms 16 ms 15 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10 20 ms 16 ms 18 ms 132.185.255.148
11 15 ms 15 ms 15 ms bbc-vip114.telhc.bbc.co.uk [212.58.244.69]
Trace complete.
C:\Users\Private>
27-02-2013 10:45 PM
Most importantly, when are you going to put this on your system status page and make it a known and official problem that's being investigated?
27-02-2013 10:47 PM
dick:quote
27-02-2013 10:48 PM
Ex-Plusnet Jobsbody
27-02-2013 10:54 PM
27-02-2013 11:01 PM
Quote from: theoddbot Most importantly, when are you going to put this on your system status page and make it a known and official problem that's being investigated?
Why isn't it also shown on the "Priority Problems" page - http://www.plus.net/support/service/problems/index.php ?
Is this NOT a problem, or is it NOT a priority ?
27-02-2013 11:38 PM
Regards
Mike
27-02-2013 11:54 PM
This all smacks of what happened at an old ISP. The problem was very similar to this and was never sorted properly whilst I was waiting, which was at least 6 months.
Whilst I appreciate that the staff at Plusnet are trying to do their best to resolve this issue, the fact of the matter is the broadband service does not currently fit the product it is sold as on the sites homepage which is as 'reliable' broadband. In my experience so far it has been anything but - you certainly cannot rely on it at peak times. This needs to be sorted, and quickly, or people will vote with their feet. I am already thinking it's MAC time and I have been with PN less than a month and the ongoing fault, coupled with this has really made me think it just isn't worth the hassle.
If there was a discount for managing your own congested gateway then fine, but there isn't. I'm sure there should be some sort of software algorithm that should flip you around automatically when congestion becomes a problem, I'm sure it wouldn't be that hard to do as the current situation is plainly wrong and cannot be allowed to go on. After all, if an IT consultant was being paid to do all this fault finding, they'd be off to Barbados for a few weeks after it all. However we are paying to put up with slow service speeds, a fault that isn't getting fixed and also to do our own fault finding and analysis. Something is very wrong with this picture.
This evenings stats from me:
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/0cde42ce765489e8a0e9ad1cfb267aeb.html"><img alt="My Broadband Ping - austinsom" src="http://www.thinkbroadband.com/ping/share-large/0cde42ce765489e8a0e9ad1cfb267aeb.png" /></a>
Speeds and ping on 'instant tests' seem to be more or less pack to normal:
Gateway is: ptn-ag04
Even the forum isn't working properly!
27-02-2013 11:57 PM
20CN ptn-ag04 nothing really exciting to report, pretty much as last night. No speed reductions noticed, other than one bad test on BT speedtester which wasn't repeated and iPlayer Diagnostics were fine. Pings started to be a bit wild after 8.00pm, normal is typically 36/37ms on this Gateway, and started to peak between 50 & 60 ms typically by about 8.30pm continuing until around 10.00pm with very occasional large peaks when they started reducing. Generally it was a bit better than last night, and apart from a burst of high pings over 100 ms between 2240 &2243 things have been pretty much as normal for just over an hour now.
28-02-2013 12:04 AM
@austinsom - I'm really sorry that this problem is affecting your service so much, honestly, we are working hard to try to get to the bottom of it. I would be more than happy to take a look at your line just to be sure there isn't anything that could be causing issues?
@Anotherone - See Kelly's response here: http://community.plus.net/forum/index.php/topic,111170.msg965039.html#msg965039 - that gives a bit of an insight into what's been happening on a couple of the affected gateways this evening too.
28-02-2013 12:13 AM
0006 had the following pings, not surprised really considering all the downloads that people start at midnight
Reply from 212.159.6.10: bytes=32 time=48ms TTL=250
Reply from 212.159.6.10: bytes=32 time=101ms TTL=250
Reply from 212.159.6.10: bytes=32 time=51ms TTL=250
Reply from 212.159.6.10: bytes=32 time=46ms TTL=250
Reply from 212.159.6.10: bytes=32 time=43ms TTL=250
Reply from 212.159.6.10: bytes=32 time=87ms TTL=250
Reply from 212.159.6.10: bytes=32 time=41ms TTL=250
Reply from 212.159.6.10: bytes=32 time=86ms TTL=250
Reply from 212.159.6.10: bytes=32 time=42ms TTL=250
Reply from 212.159.6.10: bytes=32 time=40ms TTL=250
Reply from 212.159.6.10: bytes=32 time=44ms TTL=250
Reply from 212.159.6.10: bytes=32 time=88ms TTL=250
Reply from 212.159.6.10: bytes=32 time=45ms TTL=250
Reply from 212.159.6.10: bytes=32 time=74ms TTL=250
Reply from 212.159.6.10: bytes=32 time=75ms TTL=250
Reply from 212.159.6.10: bytes=32 time=39ms TTL=250
Reply from 212.159.6.10: bytes=32 time=76ms TTL=250
Reply from 212.159.6.10: bytes=32 time=80ms TTL=250
Reply from 212.159.6.10: bytes=32 time=123ms TTL=250
Reply from 212.159.6.10: bytes=32 time=79ms TTL=250
