Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
27-02-2013 10:33 AM
As Chris says, if you've got a fault raised it will be much easier for me to obtain further diagnostics with our suppliers.
@ricmelia
If you are going to be online tonight, there might be a few little things that I would like you to do if it's not too much trouble?
27-02-2013 10:43 AM
FYI my fault ticket is 66179821
27-02-2013 10:44 AM
27-02-2013 10:48 AM
27-02-2013 1:49 PM
Quote from: Kelly Who are you using for the IPv6 tunnel?
I'm using Hurricane Electric's London server. (tserv5 to be precise)
27-02-2013 2:39 PM
Download speed a little short of what it should be considering my ip profile of 67Mbps upload speed is also slower .
This is what a normal traceroute would be for me .
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.246.92]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 16 ms 18 ms 20 ms lo0-central10.ptw-ag03.plus.net [195.166.128.197
3 14 ms 14 ms 14 ms link2-central10.ptw-gw02.plus.net [84.93.248.66]
4 15 ms 14 ms 14 ms xe-7-2-0.ptw-cr02.plus.net [212.159.1.22]
5 15 ms 14 ms 14 ms ae2.ptw-cr01.plus.net [195.166.129.4]
6 14 ms 14 ms 14 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 22 ms 16 ms 16 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
9 16 ms 16 ms 17 ms 132.185.255.165
10 15 ms 15 ms 15 ms bbc-vip013.cwwtf.bbc.co.uk [212.58.246.92]
Trace complete.
C:\Users\Private>
27-02-2013 6:38 PM
27-02-2013 6:45 PM
on ptw-ag04
27-02-2013 6:46 PM
27-02-2013 7:11 PM
Quote from: ricmelia yes, i'm seeing this too - on 33Mb down at the moment
on ptw-ag04
Ricmelia: can you stay on that gateway until your speed bottom outs. The get a speedtest and post it here. Then reboot your modem to gateway hop and do a speedtest again. I'm half expecting you to see high speeds again after that reboot. Speedtest, post it and let us know what gateway you are on.
If that happens, keep your eye on it and post speed test if you drop again. If you get slow again, reboot and see if it repeats.
I want to prove this 'change gateways and it goes away' theory we've seen. I've definitely seen two customers do this and effectively swap gateways!
Ex-Plusnet Jobsbody
27-02-2013 7:13 PM
27-02-2013 7:14 PM
27-02-2013 7:18 PM
Quote from: Kelly Then reboot your modem to gateway hop
Do i need to restart the router or just press disconnect/reconnect the internet on the "broadband connection" page?
27-02-2013 7:20 PM
27-02-2013 7:21 PM
Quote from: Kelly I want to prove this 'change gateways and it goes away' theory we've seen. I've definitely seen two customers do this and effectively swap gateways!
This has been my experience for the most part, Kelly. I start off and things may be reasonable. Then they gradually degrade, so I gateway hop and things are ok again for a while before a repeat of the degradation. I say 'for the most part' because it doesn't always work. Lately, in fact, it hasn't worked much at all and when I jump gateway it can be appallingly bad straight away.
