Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
20-02-2013 7:55 PM
I'm still on 'ptn-ag01'
My TBB ping chart looks about the same as this time yesterday.
Pingtest to my usual fastest test server 'Xilo' was 42ms with 2ms jitter only half an hour ago, but is starting to creep up.
20-02-2013 8:07 PM
Here we go AGAIN !
20-02-2013 8:12 PM
2 195.166.128.182 lo0-central10.pcl-ag01.plus.net 198 ms
20-02-2013 8:19 PM
20-02-2013 8:33 PM
C:\Users\Andrew-PC>pathping bbc.co.uk
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
0 Andrew-PC [192.168.1.33]
1 www.asusnetwork.net [192.168.1.1]
2 lo0-central10.ptw-ag03.plus.net [195.166.128.197]
3 link4-central10.ptw-gw02.plus.net [84.93.248.70]
4 xe-7-2-0.ptw-cr02.plus.net [212.159.1.22]
5 ae2.ptw-cr01.plus.net [195.166.129.4]
6 kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * *
Computing statistics for 150 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0 Sandra-PC [192.168.1.33]
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% www.asusnetwork.net [192.168.1.1]
0/ 100 = 0% |
2 --- 100/ 100 =100% 100/ 100 =100% lo0-central10.ptw-ag03.plus.net [195.166.128.197]
0/ 100 = 0% |
3 --- 100/ 100 =100% 100/ 100 =100% link4-central10.ptw-gw02.plus.net [84.93.248.70]
0/ 100 = 0% |
4 19ms 0/ 100 = 0% 0/ 100 = 0% xe-7-2-0.ptw-cr02.plus.net [212.159.1.22]
0/ 100 = 0% |
5 19ms 1/ 100 = 1% 1/ 100 = 1% ae2.ptw-cr01.plus.net [195.166.129.4]
0/ 100 = 0% |
6 8ms 0/ 100 = 0% 0/ 100 = 0% kingston-gw.thdo.bbc.co.uk [212.58.239.6]
Trace complete.
Download speedachieved during the test was - 32.89 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-96.54 Mbps .
Additional Information:
IP Profile for your line is - 96.54 Mbps
Upload speed achieved during the test was - 14.19Mbps
Upstream Rate IP profile on your line is - 15 Mbps
20-02-2013 8:47 PM
Ex-Plusnet Jobsbody
20-02-2013 8:53 PM
1 0ms 0/ 50 = 0% 0/ 50 = 0% RTA1335.home [192.168.1.1]
0/ 50 = 0% |
2 50ms 0/ 50 = 0% 0/ 50 = 0% lo0-central10.ptn-ag04.plus.net [195.166.128.193]
0/ 50 = 0% |
3 50ms 0/ 50 = 0% 0/ 50 = 0% link7-central10.ptn-gw01.plus.net [84.93.248.236]
0/ 50 = 0% |
4 46ms 0/ 50 = 0% 0/ 50 = 0% xe-10-1-0.ptw-cr01.plus.net [212.159.1.44]
0/ 50 = 0% |
5 46ms 0/ 50 = 0% 0/ 50 = 0% te9-4.ptn-gw01.plus.net [195.166.129.33]
0/ 50 = 0% |
6 54ms 0/ 50 = 0% 0/ 50 = 0% vl55.ptn-lb01.plus.net [212.159.2.124]
0/ 50 = 0% |
7 55ms 0/ 50 = 0% 0/ 50 = 0% ntp.plus.net [212.159.6.10]
Trace complete.
20-02-2013 9:22 PM
Although a traceroute to bbc.co.uk seems slower than I first had when I first joined, but still pretty much normal:
$ traceroute bbc.co.uk
traceroute to bbc.co.uk (212.58.241.131), 30 hops max, 60 byte packets
1 dsldevice.lan (192.168.1.254) 83.613 ms 83.499 ms 80.240 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 29.077 ms 29.067 ms 29.057 ms
3 link4-central10.pcl-gw02.plus.net (84.93.249.38) 28.920 ms 28.924 ms 28.938 ms
4 50.core.plus.net (212.159.1.50) 28.235 ms 28.253 ms 28.224 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 28.832 ms 28.821 ms 28.823 ms
6 ae1.ptw-cr01.plus.net (195.166.129.0) 28.813 ms 24.805 ms 24.781 ms
7 kingston-gw.thdo.bbc.co.uk (212.58.239.6) 24.767 ms 24.944 ms 28.069 ms
8 * * *
9 ae1.er01.rbsov.bbc.co.uk (132.185.254.46) 27.849 ms 27.804 ms 27.763 ms
10 132.185.255.60 (132.185.255.60) 27.754 ms 27.739 ms 29.961 ms
11 virtual-vip.thdo.bbc.co.uk (212.58.241.131) 26.564 ms 29.875 ms 29.307 ms
FYI, I am on the Retford exchange and I am on gateway pcl-ag02.
20-02-2013 9:31 PM
Can still get full speedtest results on most London servers, but the graph plot of progress is quite jagged whereas it is normally quite even.
iPlayer test results are much slower than I have ever seen before -
TBB ping graph looks worse than yesterday
My FTP connection just unexpectedly got "closed by host" while attempting to upload these pictures. That has NEVER happened before.
Youtube seems OK with no stalling or frame losses.
No buffering issues on iPlayer.
eBay page loading in multiple tabs seems to be OK, where this is usually the first symptom that I see.
I don't do any gaming so can't comment on that.
20-02-2013 9:39 PM
Ex-Plusnet Jobsbody
20-02-2013 9:45 PM
BT Speedtester results even worse:
Download speedachieved during the test was - 5.72 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-65.89 Mbps .
IP Profile for your line is - 65.89 Mbps
Upload Speed
9.99 Mbps
0 Mbps 20 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 9.99Mbps
ETA: Switching to gateway ptw-ag03 has got speeds back to more what they should be (around 60Mbps) with 30ms pings. Something about pcl-ag02 isn't right tonight.
20-02-2013 9:47 PM
When it becomes a problem for me is when I open many tabbed eBay pages, and I end up having to refresh each tab because the page hasn't loaded, but that isn't happening just now.
20-02-2013 10:22 PM
My speeds are well down:
and my ping graph is atrocious:
Tracerts seem to be 'okay', although a little slower than usual.
1 8 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 14 ms 14 ms 15 ms lo0-central10.ptw-ag03.plus.net [195.166.128.197]
3 14 ms 14 ms 13 ms link10-central10.ptw-gw02.plus.net [84.93.248.82]
4 33 ms 35 ms 34 ms xe-7-2-0.ptw-cr02.plus.net [212.159.1.22]
5 13 ms 13 ms 13 ms ae2.ptw-cr01.plus.net [195.166.129.4]
6 37 ms 32 ms 31 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 14 ms 14 ms 13 ms ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
9 33 ms 34 ms 36 ms 132.185.255.60
10 34 ms 35 ms 33 ms virtual-vip.thdo.bbc.co.uk [212.58.241.131]
Initially on ptw-ag03. Whilst testing, I was disconnected and came back on pcl-ag02. No issues for me on that gateway.
It all seems very random - i.e. not affecting a particular gateway, or PN datacentre. I'm wondering if the problem might actually be in the BT wholesale network? Reconnecting PPPoE will force a new circuit through the network and my theory is that a lot of VPs might be running hot with the massive takeup in FTTC?
I'm in Slough, and tonight is the first time I've experienced this issue first-hand. Anyone else having issues in this area tonight?
EDIT: Seems like I had the opposite experience as tgheretford here.
20-02-2013 10:42 PM
Quote from: Barry I'm wondering if the problem might actually be in the BT wholesale network?
That was my conclusion yesterday when my pingtest results were better from foreign sites than anywhere in the UK.
If this was a Plusnet problem then all connections would be equally affected - whether UK or abroad.
If this is a BT issue then UK sites would be problematic, but international routes may be different - which is what I saw !
http://community.plus.net/forum/index.php/topic,111170.msg962069.html#msg962069
21-02-2013 12:17 AM
