Peak time latency spikes
englishrick
Re: Peak time latency spikes
5am rollcall
ClaretMatt
Ping's a bit high for fibre innit?
englishrick
It was about 5 when I first joined when I was getting 75+Mbps speeds.. Speeds gone down and pings gone up lol
dick:quote
Bright
That's probably the effect of the DLM. It increases interleaving and FEC to stabilise the line. Which reduces throughput and increases latency  Sad
dick:quote
englishrick
Line was stable at 75+Mbps speeds until I changed the cable..
dick:quote
Bright
Which cable?Huh
englishrick
Quote from: Bright
Which cable?Huh
I changed cable from bt socket to modem to shorter one, it was changed back a couple weeks ago but speeds and btw profile not gone back to what they were previously and plusnet profile went down also.. Maxing out connection when it's off peak...
darklight
englishrick the DLM kicked in that fast  Shocked , you can't turn off your modem give it a moment and fire it back up like with the ADSL.
I did reboots of modem/router on my old ADSL now and again, i never got a bad profile, well unless i did it in say at 11pm at night.
I maybe off on hols later in the year i usually shutdown the modem and router but now i may have to rethink that.
w23
Fixes: 4
Try to avoid disconnecting the modem for a while, it can take weeks of stable connection for FTTC to raise the sync. speed if it has dropped due to instability or high errors.
Call me 'w23'
Bjn
My IP profile came back up after 4 days but drop was only 5Mb, never did find out why it went down overnight, but leave all alone and hopefully it will settle down
Yesterdays white boxs stats and another day of no problems looking better by the day that PN guys have solved the 8-10pm problem, and todays results looking good so far.
Downstream Throughput
Date 19.03.2013
Average (Mbps)
22:00 54.12
20:00 55.39
18:00 51.31
16:00 52.38
10:00 51.34
04:00 52.36
Anotherone
Champion
Fixes: 21
Not advised to turn off/reboot the modem as englishrick knows!
darklight
On ADSL it wasn't much of a big problem the DLM, is it that critical now on FTTC, 1 reboot of the modem and your speed drops.
Anotherone
Champion
Fixes: 21
Have you not read the PM I sent you. Yes Fibre DLM is quite aggressive and is NOT like ADSL DLM!
darklight
Yes just noticed it Anotherone.
AndyH
Speeds already off 20Mbps or so on pcl-ag04
