Peak time latency spikes
- News & Announcements
- Community Announcements
- Re: Peak time latency spikes
19-03-2013 8:07 AM
19-03-2013 8:31 AM
2 111ms 0/ 20 = 0% 0/ 20 = 0% lo0-central10.ptn-ag04.plus.net [195.166.128.193]
0/ 20 = 0% |
3 38ms 0/ 20 = 0% 0/ 20 = 0% link1-central10.ptn-gw01.plus.net [84.93.248.224]
0/ 20 = 0% |
4 38ms 0/ 20 = 0% 0/ 20 = 0% xe-10-1-0.ptw-cr01.plus.net [212.159.1.44]
0/ 20 = 0% |
5 38ms 0/ 20 = 0% 0/ 20 = 0% te9-4.ptn-gw01.plus.net [195.166.129.33]
0/ 20 = 0% |
6 51ms 0/ 20 = 0% 0/ 20 = 0% vl55.ptn-lb01.plus.net [212.159.2.124]
0/ 20 = 0% |
7 63ms 0/ 20 = 0% 0/ 20 = 0% cdns02.plus.net [212.159.6.10]
Trace complete.
2 137ms 0/ 20 = 0% 0/ 20 = 0% lo0-central10.ptn-ag04.plus.net [195.166.128.193]
0/ 20 = 0% |
3 37ms 0/ 20 = 0% 0/ 20 = 0% link1-central10.ptn-gw01.plus.net [84.93.248.224]
0/ 20 = 0% |
0/ 20 = 0% |
0/ 20 = 0% |
6 52ms 0/ 20 = 0% 0/ 20 = 0% vl55.ptn-lb01.plus.net [212.159.2.124]
0/ 20 = 0% |
7 37ms 0/ 20 = 0% 0/ 20 = 0% cdns02.plus.net [212.159.6.10]
Trace complete.
19-03-2013 8:49 AM
19-03-2013 9:13 AM
Would you be able run us the BT Speedtester again please? I'll use the information I get from this test as part of reporting an issue on your line.
We are also seeing a Major Service Failure in your area which may be affecting things too. It should have cleared by now, I'll keep an eye on that you keep you in the loop.
Please let me know once you've complete the BT Speedtester.
19-03-2013 9:24 AM
http://community.plus.net/forum/index.php/topic,111793.0.html
Basically I was querying why, while running a load balanced download across both my lines the line with the JL login had barely no increase in latency while the line with the Plusnet login had very large increases in latency, similar to what we are seeing now.
Would this give any clues to where the problem lies?
I'm still getting the spikes in peak time.
The chart below shows a youtube stream at 8.30pm and the same stream at 11.30pm.
![](http://i256.photobucket.com/albums/hh169/gmoorc/Latency2.jpg)
19-03-2013 9:27 AM
19-03-2013 9:54 AM
If you could raise a fault at http://faults.plus.net I'd be more than happy to take a further look into your line for you.
I've taken a general look at your line and it's showing a decrease on your bRAS Profile and your line quality isn't looking all that good, so I'd be keen to get that sorted out for you.
19-03-2013 9:58 AM
The BT checker is playing up - says my download speed is 107Mbps (higher than my profile with BT/PN) and when I do a Further Diagnostics I get "The Performance Test cannot proceed with the Post Code option as no suitable addresses have been found. Please check the post code or use the Service ID option to conduct the test. Click here to try again."
19-03-2013 10:07 AM
19-03-2013 10:12 AM
![](/skins/images/227CE3BD5A7F5638EDF9976F1BCF977A/responsive_peak/images/icon_anonymous_message.png)
19-03-2013 10:19 AM
Fault ticket logged reference number: 67243141 I would be grateful if you could please update me either via this thread or by adding to the ticket on my account. You will see that I have quoted this thread as I have included all the speed test results I have taken when the speeds decrease.
19-03-2013 10:42 AM
Quote from: AndyH when I do a Further Diagnostics I get "The Performance Test cannot proceed with the Post Code option as no suitable addresses have been found.
Are you getting this message after entering the telephone number?
19-03-2013 10:45 AM
19-03-2013 10:46 AM
* I'm on the Plusnet FTTP/H trial btw
19-03-2013 10:48 AM
(Jammy ba*d)
![Roll_eyes Roll_eyes](/html/@BA2C29EA5D62B3049244C6EF0F36F4A9/images/emoticons/rolleyes.gif)
