Peak time latency spikes
- News & Announcements
- Community Announcements
- Re: Peak time latency spikes
14-03-2013 10:43 PM
Well that's the first night with no problems lets hope it continues was on plc-ag01
Thanks everyone for you help
14-03-2013 10:48 PM
So where is my missing 430Mbps gone ?
It's not my modem's problem - as that is synced at max values (as it always is)
14-03-2013 10:49 PM
Ex-Plusnet Jobsbody
14-03-2013 11:02 PM
While it's quiet for the moment, what is your opinion on my question here - http://community.plus.net/forum/index.php/topic,111170.msg968147.html#msg968147 ?
It is annoying that I had interleaving switched off days before, reducing my latency by about 22ms, only to have whatever happened adding 10ms back on again !
14-03-2013 11:10 PM
Ex-Plusnet Jobsbody
14-03-2013 11:15 PM
Presumably if I had been on the failed gateway, then I would have seen a CHAP session starting around that time - but there was nothing !
14-03-2013 11:20 PM
Quote from: Kelly PCL peeps: Still seeming to be a lot better than usual?
Yes things seem better but, whilst normal ping and speedtests seem fine, this still doesn't seem as clever as it should be
Array
[0] => 1 84.92.0.73 (84.92.0.73) 0.499 ms
[1] => 2 po3.3656.peh-cr01.plus.net (84.93.232.32) 0.420 ms
[2] => 3 po5.peh-cr02.plus.net (84.93.232.17) 8.060 ms
[3] => 4 84-93-232-60 (84.93.232.60) 7.344 ms
[4] => 5 ae3.ptw-cr01.plus.net (195.166.129.32) 11.214 ms
[5] => 6 ae1.pcl-cr01.plus.net (195.166.129.1) 7.967 ms
[6] => 7 nte1.btwbmc-1.plus.net (212.159.0.177) 11.602 ms
[7] => 8 link7-central10.pcl-ag06.plus.net (84.93.249.173) 240.865 ms
[8] => 9 *
[9] => 10 *
[10] => 11 *
and I'm not too happy with BBC1 Live streaming, but this could be the Beeb (it's wiresharking OK) - occasional blocking/blurring/video jumps once or twice sound out of sync,although it's better now than it was 15 minutes ago.
purleigh's question about latency is an interesting one, because I'd been intending to ask at some point, what changes were made to pcl-ag04 about 5 weeks ago. Previous to that roughly, I'd been on pcl-ag04 for sometime and it was a good gateway for me, I could get pings of 32/33ms regularly. The last few days I've been on it until it broke this morning, the best I'd been able to get is 36/37ms.
14-03-2013 11:25 PM
Latest results I have from my whitebox on pcl-ag06
Average (Mbps)
22:00 46.09
20:00 50.29
19:00 32.24
18:00 50.41
14:00 50.46
08:00 50.70
Rather different than the usual, certainly! What happened around 19:00?
15-03-2013 6:52 AM
Ok last night was allot better I could live with those speeds if you guys at PN can maintain them they are similar to what I was getting before the problems started around 23th Feb.
Results from SamKnow box on gateway plc-ag01
Downstream Throughput
Date 14.3.2013
Average (Mbps)
0.4.00 51.62 This morning 15th feb
00.00 51.09
22:00 43.43
20:00 53.20
18:00 52.01
16:00 51.50
10:00 51.43
0.4.00 51.43 Yesterday 14th Feb
There was a small dip around 22.00 but nowhere near the ones I've been experiencing they have been going down to under 10Mbps
Still on same gateway atm will check tonight to see what results I get
15-03-2013 8:05 AM
(Ignore the red in the Tbb graph - I had to move furniture around which involved disconnection etc......
Link removed
15-03-2013 8:18 AM
15-03-2013 8:24 AM
Tell me, are you as content this morning as I am or are you suffering your usual slowdowns etc?
15-03-2013 8:42 AM
15-03-2013 8:57 AM
Quote from: purleigh 20CN on 'pcl-ag01'
Dropping from 6.9Mb to 6.7Mb really isn't a huge drop and isn't a significant change. I'm sorry to say but that's well within the acceptable range of speeds for a broadband service.
15-03-2013 9:30 AM
