Peak time latency spikes
KevinG
Re: Peak time latency spikes
All OK for me, Currently on pcl-ag02.
englishrick
1. Best Effort Test:  -provides background information.
Download Speed
28.74 Mbps
0 Mbps 74.02 Mbps
Max Achievable Speed
Download speedachieved during the test was - 28.74 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-74.02 Mbps .
Additional Information:
IP Profile for your line is - 74.02 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
13.16 Mbps
0 Mbps 20 Mbps
AndyH
pcl-ag03 isn't looking too good:
BT Checker
Download Speed (Mbps): 23.1
Upload Speed (Mbps): 13.55
Ping Latency (ms) 100.88
Strange thing is downloads are poor (tried some large files on university mirrors) as are the speed tests, but pings are fine:
Ping statistics for 212.159.13.50 (bbc.co.uk):
   Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 4ms, Maximum = 6ms, Average = 4ms
Ping statistics for 23.62.53.114 (ntp.plus.net):
   Packets: Sent = 50, Received = 50, Lost = 0 (0% loss),
   Minimum = 4ms, Maximum = 12ms, Average = 4ms
jamesanstee
Tracerout to bbc.co.uk
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Users\Private>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.244.67]
over a maximum of 30 hops:
  1    1 ms    1 ms    1 ms  192.168.1.1
  2  163 ms  118 ms  103 ms  lo0-central10.pcl-ag02.plus.net [195.166.128.183
  3    43 ms    24 ms    19 ms  link8-central10.pcl-gw02.plus.net [84.93.249.46]
  4    18 ms    18 ms    18 ms  50.core.plus.net [212.159.1.50]
  5    19 ms    19 ms    19 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  6    19 ms    19 ms    19 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  7    18 ms    30 ms    18 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  8    *        *        *    Request timed out.
  9    *        *        *    Request timed out.
10    19 ms    19 ms    18 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
11    24 ms    20 ms    21 ms  132.185.255.148
12    19 ms    19 ms    19 ms  bbc-vip112.telhc.bbc.co.uk [212.58.244.67]
Trace complete.
austinsom
Currently on ptw-ag03 and have what I would best describe as lumpy speed and packet loss.  The speedtest graph stays flat then peaks and drops back again.  Same with upload speed.  Pingtest shows no packet loss, but TBB graph is showing quite a few red peaks this evening, suggesting there is packet loss.  I am going to try hopping to a different gateway to solve this as I will be on XBL later and any packet loss will make it unusable.
Results:
20CN, 'pcl-ag02'
Already seeing problems  Roll_eyes
My 'normal' results are shown below -
dave
Fixes: 13
AndyH - going to run some tests on your connection first, will make a change at exactly 8pm to see if that makes any difference (just for you and anyone else on pcl-ag03) so if you can let me know before and after that would be appreciated.
PS: don't disconnect Smiley
Dave Tomlinson
Plusnet Technology
Finguz
Quote from: AndyH
That's where all my problems started last night  Sad
Edit: Doh, nope it was pcl-ag04  Roll_eyes
[me=Finguz]lovingly pats ptn-ag02..[/me]
KevinG
Quote from: purleigh
20CN, 'pcl-ag02'
Well I don't think there's anything inherently up with pcl-ag02 because it's still perfectly fine for me.
AndyH
Still on PCL-AG03 Smiley
This is my last speed test:
jamesanstee
Speedtest from BT Wholesale tester taken at 20:00  BBC Iplayer streaming in low bandwidth constant buffering itv player just buffers and fails to load content.
Still currently connected to gateway pcl-ag02 same gateway as i was on last night .
FAQ
Download Speed
10.32 Mbps
0 Mbps 67.49 Mbps
Download speedachieved during the test was - 10.32 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-67.49 Mbps .
IP Profile for your line is - 67.49 Mbps
Upload Speed
7.81 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 7.81Mbps
dave
Fixes: 13
OK, give it another minute, the change took me longer than I expected.
Dave Tomlinson
Plusnet Technology
bifkinuk
ptn-ag03
Anotherone
Champion
Fixes: 21
@purleigh & @KevinG
This isn't the first time that different people on the same Gateway have had major differences.
Don't know if posting a traceroute to say ntp.plus.net would show anything.
bifkinuk
ptn-ag03
BT Wholesale Broadband Performance Test:
Download Speed (Mbps): 3.57
Upload Speed (Mbps): 10.09
Ping Latency(ms): 45.75
Tracing route to ntp.plus.net [212.159.6.10]
 1   186 ms    97 ms    98 ms  dsldevice.lan [192.168.1.254]
 2    35 ms    35 ms    34 ms  lo0-central10.ptn-ag03.plus.net [195.166.128.192
 3    25 ms    24 ms    30 ms  link5-central10.ptn-gw01.plus.net [84.93.248.200
 4    23 ms    24 ms    23 ms  xe-8-2-0.ptw-cr01.plus.net [212.159.1.32]
 5    25 ms    25 ms    24 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
 6    23 ms    23 ms    25 ms  vl55.ptn-lb01.plus.net [212.159.2.124]
 7    23 ms    24 ms    25 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
