Peak time latency spikes
Re: Peak time latency spikes
Tonight was MUCH better, just slowed a little around 22:00.
Cool  Smiley  Huh
Anotherone
Champion
Fixes: 21
HTH. ptw-ag04 21CN LVRNE (not my connection by the way) fine tonight TBB pings perfectly normal, not showing any of the nasty problems that was evident last night when they were on ptw-ag03, but was worse than what Barry was seeing before he changed Gateway.
ITWorks
Fixes: 9
Last night was not to bad, but at 5.30am this morning its the worst it has even been, what could be causing this as obviously this is not peak time?  Sad
pcl-ag05 (20CN connection)
Edit: back to normal , ptw-ag04
Regards Mike
Here is an TBB graph update for after midnight when my iPlayer download server kicked in !
Kelly
Fixes: 9
Quote from: I
There was bt maintenance this morning which could have caused it.
Kelly Dorset
Ex-Plusnet Jobsbody
ITWorks
Fixes: 9
Thanks for the info Kelly  Smiley
Regards Mike
jamesanstee
Speeds were back to normal today but have now stared to see the slowdown appear again .I see a fault ticket has been raised on my line ticket number 66218711 im wondering if the issues im having are anything to do with the openreach work my neighbour had done a few weeks ago where they dug outside my property and changed something but at the same time knocked out my line but reconected it after i had told them they hit my line quiet line tests appear ok no noise or cross talk but just maybe a coincidence.
kareha
What is generally the best gateway to be on incase of having to switch around?
jamesanstee
Speed back to normal at the moment but not holding out much hope in it staying that way.
Kelly
Fixes: 9
Friday nights are usually quite quiet.  If this is being driven by traffic contention somewhere, it may all be fine!
Kelly Dorset
Ex-Plusnet Jobsbody
jamesanstee
Think i spoke a bit too soon
odged
It's good to see that people are aware of the problem at PlusNet. It gives me more confidence in the service  and to continue paying .
I'm currently getting pings to the servers I normally play Tf2 on over 700+ which are normally stable 24ms.
I hope you can sort out the issues soon and will continue to keep disconnecting until I connect to a better
gateway than:-pcl-ag05.
 Which gateway
You are currently connected to the gateway known as pcl-ag05.
To Server Maidenhead 51mls
Ping test gives Plusnet an F  206ms ping 81% Packet loss 66msJitter
Not great.
ntp.plus.netMicrosoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights
>ping ntp.plus.net
Pinging ntp.plus.net [212.159.6.10] with 32 bytes of
Reply from 212.159.6.10: bytes=32 time=154ms TTL=246
Reply from 212.159.6.10: bytes=32 time=133ms TTL=246
Reply from 212.159.6.10: bytes=32 time=142ms TTL=246
Reply from 212.159.6.10: bytes=32 time=119ms TTL=246
Ping statistics for 212.159.6.10:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% los
Approximate round trip times in milli-seconds:
   Minimum = 119ms, Maximum = 154ms, Average = 137ms
It's so rubbish at the moment I hope it gets better.
Anotherone
Champion
Fixes: 21
Quote from: kareha
What is generally the best gateway to be on in case of having to switch around?
It seems to be a bit hit and miss at the moment. You can't choose a gateway anyway, you just have to hop and hope you get one that's good for you.
Anotherone
Champion
Fixes: 21
@odged
Try pinging ntp.plus.net. That way you aren't influenced by factors outside your connection to Plusnet and the Plusnet network.
Also ping bbc.co.uk is another good one to try, but that of course goes out to the beeb.
Joopzor
I notice every evening i cant stream to twitch.tv without 1 sec pauses and its the same for Viewing! is this low traffic?Huh
