Peak time latency spikes
pengbo
Re: Peak time latency spikes
How do you tell which gateway you are on? Sure I have seen it somewhere but I think I just clicked on all the obvious icons in my  account and could not see it  Sad
Kelly
Fixes: 9
http://usertools.plus.net/@gateway/
Kelly Dorset
Ex-Plusnet Jobsbody
pengbo
Thanks Kelly. No wonder I couldn't find it lol  Crazy
Edit to add: appears I am on pcl-ag02 and probably have been for last 10 days as according to my router it has an uptime of 250 hours on WAN2 PPPoE
AndyH
Back to normal again:
Tracing route to www.bbc.net.uk [212.58.244.67]
over a maximum of 30 hops:
  0  HOME-SERVER [192.168.1.100]
  1  www.asusnetwork.net [192.168.1.1]
  2  lo0-central10.pcl-ag07.plus.net [195.166.128.188]
  3  link7-central10.pcl-gw01.plus.net [84.93.249.204]
  4  xe-2-2-0.pcl-cr01.plus.net [212.159.1.12]
  5  ae2.pcl-cr02.plus.net [195.166.129.7]
  6  ae2.pcl-cr01.plus.net [195.166.129.6]
  7  ae1.ptw-cr01.plus.net [195.166.129.0]
  8  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  9    *        *        *
Computing statistics for 200 seconds...
            Source to Here  This Node/Link
Hop  RTT    Lost/Sent = Pct  Lost/Sent = Pct  Address
                                0/ 100 =  0%  |
  1    0ms    0/ 100 =  0%    0/ 100 =  0%  www.asusnetwork.net [192.168.1.1]
                                0/ 100 =  0%  |
  2    9ms    0/ 100 =  0%    0/ 100 =  0%  lo0-central10.pcl-ag07.plus.net [1
95.166.128.188]
                                0/ 100 =  0%  |
  3    5ms    0/ 100 =  0%    0/ 100 =  0%  link7-central10.pcl-gw01.plus.net
[84.93.249.204]
                                0/ 100 =  0%  |
  4    7ms    0/ 100 =  0%    0/ 100 =  0%  xe-2-2-0.pcl-cr01.plus.net [212.15
9.1.12]
                                0/ 100 =  0%  |
  5    7ms    0/ 100 =  0%    0/ 100 =  0%  ae2.pcl-cr02.plus.net [195.166.129
.7]
                                0/ 100 =  0%  |
  6    7ms    0/ 100 =  0%    0/ 100 =  0%  ae2.pcl-cr01.plus.net [195.166.129
.6]
                                0/ 100 =  0%  |
  7    9ms    0/ 100 =  0%    0/ 100 =  0%  ae1.ptw-cr01.plus.net [195.166.129
.0]
                                0/ 100 =  0%  |
  8    5ms    0/ 100 =  0%    0/ 100 =  0%  kingston-gw.thdo.bbc.co.uk [212.58
.239.6]
tijara33
Fixes: 6
Noisy?
Sudden increase in latency with increased spikes & my speed dropped fro 45 down to between 5 & 10!!! After an internal reboot I'm now on ptn-ag01 & things are back to normal. You can clearly see the "hump" in the green while I was on pcl-ag01.
rongtw
Fixes: 12
ptw-ag03. tonite playing bf3 21.40 my ping jumped from 17 to 48 - 60 for 10 mins .
no graphs running sorry
bobpullen
Fixes: 330
Quote from: Kelly
Gus:  We've got a device having trouble again on your gateway.  PCL-AG07/08.   Someone is looking at it now.
I'm on PCL-AG06 and considering I've hardly been using my connection (until now), my latency/packet loss didn't look clever earlier Sad
Zico
Gateway ptn-ag04 attached.
The thin spikes before 8pm are specific to problems on my line only.
shure
have to be honest I'm not loving pcl-ag07.  Just had a very troubled Skype conversation and pingtest showed me why:
shure
...and the tracert test to bbc.co.uk.  The symmetry is rather spoiled by line twelve but otherwise the best you can say about it is that it's very consistent Sad
shure
...and finally, when I try to run the BT speedtest I get this:
"The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider."
I can bring up web pages, by the way.  Any ideas what's going on?  TBB attached which if I'm honest doesn't look too bad, so at a loss to explain why the other results are so shocking Huh
Kelly
Fixes: 9
Skype was troubling?  Drop outs?  Garbled?
Kelly Dorset
Ex-Plusnet Jobsbody
shure
stuttering audio.  Banner appeared at the bottom of the screen advising to switch off video due to poor connection.
alegeek
This is dreadful, I manage to get on a good gateway and it soon becomes a nightmare..
traceroute to bbc.co.uk (212.58.241.131), 64 hops max, 52 byte packets
1  192.168.2.1 (192.168.2.1)  3.701 ms  1.165 ms  4.702 ms
2  lo0-central10.pcl-ag03.plus.net (195.166.128.184)  72.139 ms  58.077 ms  89.023 ms
3  link2-central10.pcl-gw02.plus.net (84.93.249.66)  37.783 ms  40.319 ms  37.633 ms
4  xe-1-2-0.pcl-cr02.plus.net (212.159.1.6)  70.591 ms  64.327 ms  37.972 ms
5  ae2.pcl-cr01.plus.net (195.166.129.6)  49.390 ms  39.817 ms  39.258 ms
6  ae1.ptw-cr01.plus.net (195.166.129.0)  62.298 ms  46.879 ms  38.325 ms
7  kingston-gw.thdo.bbc.co.uk (212.58.239.6)  69.867 ms  37.587 ms  47.646 ms
8  * * *
9  ae1.er01.rbsov.bbc.co.uk (132.185.254.46)  46.502 ms  39.087 ms  41.105 ms
10  132.185.255.60 (132.185.255.60)  45.991 ms  53.313 ms  49.830 ms
11  virtual-vip.thdo.bbc.co.uk (212.58.241.131)  37.729 ms  37.239 ms  40.960 ms
I also get "The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider." when trying to run a bt speedtest.
I think I'll be making more use of my backup BT connection.
Kelly
Fixes: 9
what's dreadful?  What are you seeing now?
Kelly Dorset
Ex-Plusnet Jobsbody
