ADSL Router firmware testing
- News & Announcements
- Community Announcements
- ADSL Router firmware testing
Re: ADSL Router firmware testing
28-12-2012 5:28 PM
29-12-2012 2:56 AM
Quote from: aam Is the test firmware for the TG582n newer than the 10.2.2.9 version? If so, I'd be interested.
Also will the update be pushed by TR-069 to those selected, or will it have to be installed manually?
Why is my router only running:
Software Release: 8.4.4.J
This normal?
29-12-2012 9:16 AM
Thanks.
29-12-2012 3:59 PM
Up to now -before i came to the UK- all the routers had a firmware update option through the router's page.
29-12-2012 6:42 PM
30-12-2012 4:14 PM
During the transfer process -before installation- it just says that it failed.
I'm using tp link powerline.Could this be a reason.Got my desktop on a different floor.
30-12-2012 6:35 PM
30-12-2012 6:36 PM
31-12-2012 9:38 PM
31-12-2012 10:56 PM
Quote I'm using tp link powerline
dimcass that firmware tool and firmware is not for that make of router, only routers the supplied by Plusnet - Thompson and Technicolour. You trying to use it could leave you with a dead router which would require reinstalling the firmware to get it working again.
So do not try to use it unless you have the Technicolor, you should look at http://uk.tp-link.com ; But going by what you have said I would advise you not to. It is one thing you can't get wrong as the fix isn't easy
31-12-2012 11:35 PM
He's using powerline adapters to connect the PC to the router instead of having an ethernet cable trailed from one floor to another. There's no reason why that should cause an issue.
01-01-2013 12:14 AM
The best solution is probably to ask Plusnet to update it remotely when they are back on Wednesday.
01-01-2013 10:14 AM
If W7 run in compatibility mode if still not working.
01-01-2013 10:28 AM
01-01-2013 12:16 PM
I'll have to wait for a mod to see this and offer inside help.
thanks guys for your responses.
