20Mb on Value
BenTrimble
Re: 20Mb on Value
@pierre_pierre
I've updated your provisioned product and bounced your profile to match the exchange, enjoy Smiley
pierre_pierre
Re: 20Mb on Value
Tah ever so
pierre_pierre
Re: 20Mb on Value
nearly ok ? Crazy
Download speedachieved during the test was - 4987 Kbps
For your connection, the acceptable range of speedsis 2000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :16584 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 13000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.46:18.55:65.99 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
profile PN 13000
BenTrimble
Re: 20Mb on Value
Seen a PPP drop yet? If not, reboot your router and the new profile will take effect Smiley
pierre_pierre
Re: 20Mb on Value
power down twice, first a power cut, second me,  seems to be capped
Download speedachieved during the test was - 5476 Kbps
Your DSL Connection Rate :15448 Kbps(DOWN-STREAM), 1048 Kbps(UP-STREAM)
The throughput of Best Efforts (BE) classes achieved during the test is - 8.95:27.29:63.77 (SBE:NBE:PBE)
adamwalker
Fixes: 223
Re: 20Mb on Value
Hi pierre_pierre,
I've just run a DSL status check and checked your profile on our side, all seems to match up so we may be looking at a poor performance fault here.
We'd recommend raising a fault, let us know if you need any assistance.
Adam.
 Adam Walker
pierre_pierre
Re: 20Mb on Value
stage one of fault completed id34775959 the auto found nothing
nadger
Re: 20Mb on Value
@pierre_Pierre I'd have thought, by now, you'd be easily beating my download speeds so looks like a fault somewhere.
Download speed achieved during the test was - 6964 Kbps
For your connection, the acceptable range of speeds is 1000-7150 Kbps.
Your DSL Connection Rate :8828 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.16:24.31:60.53 (SBE:NBE:PBE)
pierre_pierre
Re: 20Mb on Value
yes its peculier
Just tried my netbook with linux via ethernet, mybroadband speed test
up 886  down 12145
BT speed 8886 down
but this XP laptop on the same router wifi is giving bad results, I thought that the BT test went from the router, so why the difference?
Its a long time since I mucked around with settings, will check SWMBO netbook next that has XP
Oldjim
Resting Legend
Fixes: 63
Re: 20Mb on Value
Have you changed the MTU and RWIN on the XP machine - if you haven't you need to
Fixes: 580
Re: 20Mb on Value
Wifi will quite often give bad results. Yes its 54Mb in theory but you'll never achieve anything like that in reality. Probably closer to 20Mb on a good day but likely much less than 10Mb if you've got any neighboring Wifi networks or more than 1 device connected.
The BT test still downloads to your PC on which you run the test so will be influenced by the connection method to the router.
pierre_pierre
Re: 20Mb on Value
just done a Drtcp test
will now try this one on ethernet
pierre_pierre
Re: 20Mb on Value
same orible speed on ethernet
pierre_pierre
Re: 20Mb on Value
Jim whats that song  "Hold my hand I am a stranger in paradise"
Never really looked at my speed on plain ADSL it was just good, now dont know
pierre_pierre
Re: 20Mb on Value
Just fired up my Win 7 desktop  (Back from repair again)
got full speed on this one, so it must be XP it doesnt like
