Static IP
andymet87
Static IP
Please can someone enable a Static IP on my connection? cannot find any settings to do this via the website... thanks!
8 REPLIES 8
Re: Static IP
Try this -
Login to your Plusnet  Member Centre
Navigate to Connection Settings
Click on the link named  Static IP  where you should be able to activate the static IP
andymet87
Re: Static IP
Thanks for the response.
I have tried doing this, which is what it says to do everywhere. But no "Static IP" link shows on that page for me...
Re: Static IP
Hmm.. that is where it is on my account (I checked before I posted the reply).
On some types of account, activating a  Static IP  used to be under the "Add-ons" section  https://www.plus.net/AddOns.html
andymet87
Re: Static IP
...that just says:
"Currently there are no Add-Ons available for your account.
Keep checking here for new Add-Ons, as-and-when they become available."
I have seen some threads saying a plusnet support person needs to do something behind the scenes...
Alex
Fixes: 13
Re: Static IP
I am on a very old package so I don't know for certain but is it the case it is only available on certain packages?
Hopefully a staff member will pick this up and will enable it for you. I believe there is a one off £5 charge for this. Not sure if that is still the case.
andymet87
Re: Static IP
It is a relatively new business package - Static IP should be free Smiley
Alex
Fixes: 13
Re: Static IP
Ah ok, maybe your account needs some updating then as it is new?
Hopefully a member of staff may pick your thread up.
adamwalker
Fixes: 223
Re: Static IP
Hi all, it's not possible to add IPs to an account prior to activation, do message me with your username if it's still an issue though and I'll get it sorted out.
 Adam Walker
