Line Speed - Help
- Business
- Line Speed - Help
Line Speed - Help
25-03-2008 10:45 AM
I have 2 teleworker accounts both with their dedicated phone lines.
Line One has been on Max ADSL for about a year or more and syncs at down 8128kbps up 832kbps. The speed obtained is around 6500 to 6600 kbps down and 715 kbps up.
Line 2 (Line in box 3 ft away from the first) was until recently a fixed 2mb line. I aked for it to be upgraded to 8mb. The line is used for a server which goes through the Netgear Gigabit 8 port ethernet switch box (as is the first) and has a 1gb speed because the server runs Windows Server 2003.
Line 2 syncs at 8128kbps up 832kbps. However the speed is still 2mb. Example 1898 kbps (237kB/s) 713 kbps (89.1kB/s). I have waited and waited for the speed to increase on download but nothing has happened. Is it stuck? Connection Settings says it set to 7000 kbps. Apart from the filter - modem and Gigabit box there is nothing else on the line whilst line one is connected to the house internally line 2 is straight in.
Can some kind soul help? Ticket ID: 24376156
Message 1 of 4
(2,935 Views)
3 REPLIES 3
Re: Line Speed - Help
25-03-2008 10:47 AM
Just to avoid any confusion, would you mind PMing me with the telephone number that you're referring to?
Message 2 of 4
(692 Views)
25-03-2008 1:24 PM
You have a pm!!
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
Message 3 of 4
(692 Views)
25-03-2008 1:51 PM
So do you
Message 4 of 4
(692 Views)
