Internet keeps disconnecting randomly
aklackhussain
Ever since I switched to plusnet from talktalk the internet will disconnect and go through a cycle we’re it takes ages to reconnect. The router will just flash orange for a while and then eventually connect. This is extremely frustrating and I am considering terminating my contract if I’m unable to resolve this. I have done all the checks e.g. line test and checked all the hardware and even connected the router to the mainline
7 REPLIES 7
Fixes: 250
Re: Internet keeps disconnecting randomly
Have you have you phoned support? Business phone support is very proficient.
Is the any noise on the phone line? Dial 17070 option 2 - the line should be silent.
TheMightyAJ
Fixes: 126
Hi @aklackhussain,
I'm really sorry to hear that you've been experiencing this issue with the connection. I've had a look into the account today and I can see that there have been drops, though our line tests haven't detected any underlying faults. You'd mentioned that you'd carried out various troubleshooting steps - when did you carry these out and have any of the changes you made to the setup been permanent, or did you return the router to it's original position after a few hours?
 Alex H
aklackhussain
Hope you are well too. So I’ve tested the internet on the test socket but this was only for a day and then I returned back to the original setup. I don’t believe there were any drops when connected to the test socket but this could have been just one of those days were there were no drops.
Fixes: 1,662
Thanks for getting back to us @aklackhussain
I've just taken a look into this for you and I can see you've had some drops last night.
Would you be able to plug your router back into the test socket and see if things drop out?
aklackhussain
So I’ve connected the router to the test socket this afternoon and will leave it overnight and monitor it. Before putting in the test socket it has been quite bad today and dropped out may times which has been extremely frustrating. So far I haven’t noticed any drop outs
aklackhussain
So the internet is still dropping even when connected to the test socket - unsure as to what the issue is, today it has been pretty bad and it has dropped multiple times throughout the day
Fixes: 1,662
I'm really sorry to see you're still having a lot of issues.
I can see you've spoken with an adviser just now and they're making some changes to your line's profile to try to make things more stable. It can take a few days for the changes to fully take effect.
Let us know how it goes as the next step if you're still having issues would likely be to arrange an Openreach engineer visit with you to investigate further.
