Home or Business Broadband
Jimboy
I am a home user and do not have a business. I would like to know if If I can have a Business broadband account and what the advantages are.
Thanks in advance
12 REPLIES 12
Legend
Fixes: 255
Re: Home or Business Broadband
@Jimboy I don't think it is possible to have a business connection as a home user, but there are very few advantages for you - and a big 'gotcha' - they are relatively expensive.
AFAIK the only differences are that you get a (very slightly) improved response time for fault resolution, and a fixed IP for nothing - but as that is a one-off £5.00 on residential accounts anyway - not worth much.
There may be other 'advantages' but I would suggest they would be of little use to a home user.
I can't really comment any further, but hopefully a PN Help Team member will comment.
pjmarsh
Fixes: 20
Other differences off the top of my head are 24/7 support and VAT invoicing
Legend
Fixes: 255
@pjmarsh , forgot those but neither are much use to a home user? (maybe 24/7 support, but why?)
198kHz
Fixes: 41
WFH?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Legend
Fixes: 255
@198kHz Maybe - but would that make me pay the extra? Don't think so. 😀
Fixes: 1,601
Thanks for your post @Jimboy
Absolutely, you can have a business account for the extra benefits even if you're not a business.
Some benefits:
  • Free static IP
  • 24/7 customer support
  • VAT invoices
  • Option to buy Enhanced Care to be given priority if you ever experience a broadband fault
Let us know if you've got any further queries.
Legend
Fixes: 255
@Gandalf Cheers for proving me wrong (again 😉). IMHO, though - is the extra cost warranted for a home user, even if they are WFH?
Fixes: 1,601
That's probably a question for the OP as I couldn't possibly answer that. Wink
Fixes: 162
@jab1
The bottom line is that under residential T&Cs anything other than incidental use for business related purposes is forbidden. The current reality of COVID has though somewhat made that a mute point.
IIRC in respect of phone line repairs there is no difference between the services. There never has been a difference in respect of broadband issues, though as Anoush notes, business can access enhanced broadband support,
Legend
Fixes: 255
@Townman I understand all that, although I don't quite see how an ISP can police the policy. Not that it matters now as I'm no longer a PN customer, but I used my connection for 'business purposes' for a couple of months a few years back when I was 'WFH' part-time after a medical problem made it hard to actually go to the office. No come-backs.
Actually, thinking back, I wasn't with PN back then, but it was still a residential account.
Fixes: 162
Having T&Cs and policing them are not the same. The issue comes when someone has bought into residential terms and then gets irate that under residential repair profiles their ability to work is severely impacted.
If one so desperately needs internet to support one’s livelihood then one should purchase a service which is more suited to that need. Plusnet might not be the best supplier for that level of dependency. Business dependency really does need same day (or 24 hour) fix for phone faults.
When the use is clearly against the T&Cs users ought not to be expecting preferential service because their ability to earn is impacted in the manner we see so very often around this forum.
Legend
Fixes: 255
Understood - and in the case I mentioned above, that was not the situation. My employers were still paying me - we had very good sick-pay terms back then - and I was WFH  by choice, if my connection failed, as it quite often did, a quick phone call and what I was working on was picked up by colleagues and the IT dept. sorted the connection issue.
