Connection issues
VAPWHIT
Connection issues
Hi, I have 9 plusnet accounts all with business fibre unlimited, a couple of them drop connection throughout the day meaning we cannot use our credit card machines. Some of these routers are quite old 5 years plus, could this be causing the problems ?
Have text the help with our phone number which comes back all good but our epos supplier says its a router problem.
3 REPLIES 3
Fixes: 1,492
Re: Connection issues
Moderators Note
This topic has been moved from Fibre to Business
Fixes: 1,654
I'm really sorry to see your business connections are dropping out.
If you can PM me your account usernames, I'll be happy to take a look for you.
Fixes: 240
Connections can drop out at various levels - WiFi or broadband and the approach to them needs to be different.
You should start by checking the quality of the phone lines. Dial 17070 option 2 and confirm that the line is silent.
Also when the PDQs lose connection check the lights on the router and see if other internet connectivity is lost.
Sometimes the issue is the PDQ itself. My local pub’s PDQ often loses its connection whilst everything else internet related is fine.
