wireless connection problems
- wireless connection problems
29-11-2009 5:27 PM
if anyone can offer any advice i would be extremely grateful.
i have just started using PN and can connect to the internet using a ethernet cable but i cannot connect using wireless. i have a full strength signal but it refuses to connect. i tried a friends' computer and his connected immediately. he has vista, i have xp. i could connect to my previous broadband provider wirelessly with no problems.
help!!
Re: wireless connection problems
29-11-2009 5:28 PM
Are you entering the password correctly? It's case sensitive.
What error are you getting?
29-11-2009 5:44 PM
29-11-2009 8:25 PM
i entered the network key in correctly (i know that's ok cos it worked on my friends computer). as for software for my wireless card, i haven t needed any when i have connected to numerous other wireless networks, do you think i need it now? if so where do you get it from.
thanks for any suggestions.
29-11-2009 8:47 PM
It might be that your computer is seeing the Thompson router but there is already a profile for a Thompson router set up in XP.
Have a look and if there is you will need to delete it.
Try Control Panel> Network Connections> right-click Wireless Network Connection> Properties> Wireless Networks tab> select the network> Remove.
29-11-2009 9:23 PM
unfortunatly it didn't do the trick.
is there anyway i can turn off the security encryption feature to see if that's the problem or am i talking rubbish. i'm desperate. everyone is tripping over the half a dozen wires i've got trailling all other the place
29-11-2009 9:50 PM
29-11-2009 10:24 PM
30-11-2009 8:38 PM
i m defenitly trying to connect to my router (the only one in my house), my friends computer connects to it immeidiatly. when i try with mine it times out without connecting after i type in the wep key. (in capitals)
i think it must be my computer not being compatible with the thomson router somehow, because i was connected to another wireless network last week.
aaaarrrrrggghhhh.
30-11-2009 8:42 PM
01-12-2009 9:04 PM
i've just been round to friends house to try connecting to his broadband wirelessly. all i got was "aquiring network address" / "disconnected".
then i came home (with a tear in my eye) and turned the security setting on my router from wpa-psk to wpa and that did nothing. then i changed it to disabled and now i can connect wirelessly to my unsecured router. everyone following so far.
i m happy with that but i still would love to know what the dickins is going on.
thanks for the advice so far
cheers
01-12-2009 11:06 PM
