were do i ask to be changed to adsl2+ please ?
matty2k13
just checked my router page and it looks like in on adsl,
DSL Type: ITU-T G.992.3
any chance i can get this changed, im on the whitehaven exchange.
thanks in advance
25 REPLIES 25
HPsauce
Re: were do i ask to be changed to adsl2+ please ?
That's ADSL2, probably set automatically when you connect due to line quality being inadequate for ADSL2+
On some longer lines it can give better results.
ejs
Aspiring Hero
Fixes: 25
A line is provisioned on either ADSL1 (ITU-T G.992.1) or ADSL2+, since you're already on ADSL2 there's nothing you need to ask Plusnet to change.
matty2k13
well when i connect on my plusnet router i sync at 921 / 3.936
and when i connect with my dg834gt i sync at 888/6010
what could be the diffrence ?
Oldjim
Resting Legend
Fixes: 63
The only way to get an idea is to post the stats - noise margin, speed and attenuation - for the two routers
matty2k13
ok i will do that now
matty2k13
i know the snr is low on the dg but it holds out and never drops
matty2k13
forgot stats for dg
Oldjim
Resting Legend
Fixes: 63
The answer is clear - although I was surprised at the big difference.
You are using the DGTeam firmware and have manually reduced the default noise margin from the 6dB default to 2.5dB
You can't do this with the Technicolor Router
matty2k13
i have just changed adsl filter and the status of the plusnet router have got better, this will do me till i get fiber in september,
Bandwidth (Up/Down) [kbps/kbps]: 961 / 4.712
Oldjim
Resting Legend
Fixes: 63
why don't you use the Netgear
I would still be using mine except it broke  Sad
matty2k13
the wifi areal has broke off inside so the sig is very poor,
matty2k13
admin please can i have a linespeed update
Oldjim
Resting Legend
Fixes: 63
I don't know what you are asking for but the IP profile can be obtained from the BT speed test - further diagnostics and the Plusnet profile is here https://portal.plus.net/my.html?action=data_transfer_speed
Oldjim
Resting Legend
Fixes: 63
You could use the Technicolor as a wireless point connecting to the Netgear by cable
