viewing youtube video
- viewing youtube video
20-03-2010 9:23 PM
Re: viewing youtube video
20-03-2010 11:39 PM
Try BBC iPlayer (for example).
20-03-2010 11:48 PM
http://www.google.com/support/youtube/bin/answer.py?hl=en-uk&answer=57669
21-03-2010 1:34 AM
21-03-2010 7:51 AM
If you look at the attached files below, one shows a screen shot of what the security settings page looks like, and the other is the associated help for these settings.
So if your Mother's Thomson router has the equivalent Java and cookie blocking capability AND it is set to filter ON, then that would explain the difference you are seeing.
21-03-2010 10:53 AM
Blocking ActiveX on a Windows system is a good idea.
Don't block javascript - no relation to java - as all / most sites will fail.
21-03-2010 12:46 PM
You can run it in the 32 bit browser in a 64 bit system, though.
Flash Player support on 64-bit operating systems
Forum Moderator and Customer
21-03-2010 1:25 PM
So if the problem really is location dependant, then that leaves -
1) Laptop Internet Security firewall blocking when on "HOME" location profile, but not blocking when "AWAY" from home.
2) Filtering by mother's router - unlikely but see my previous posting above.
3) Filtering by PlusNet firewall on mother's account - see https://portal.plus.net/my.html?action=firewall.
4) Location sensitive content filtering - such as use of OpenDNS DNS to filter mother's IP address - check DNS setting for mother's laptop and router.
5) Finger trouble ?
21-03-2010 3:50 PM
Quote from: Mav Flash won't run in a 64 bit browser under Windows.
However, Flash does run in a 64 bit browser on Linux.
21-03-2010 6:44 PM
I have looked into the 32/64-bit question, but if this is the case, it wouldn't work on my connection either - and it does.
I think your next post "Purleigh" may hold the answer - if only I could really understand most of it (bit of a novice!)
1. Laptop internet security firewall blocking when on HOME location profile, but not blocking when AWAY - I really don't understand this. She is using windows firewall. Do you mean that the settings change?
2 Filtering by router - I will check this when I can
3 Firewall on mothers account is turned off.
4. Not sure about this at all, but if I am looking in the right place. Obtain ip address automatically is checked on settings in laptop. Again I can't check router settings.
5 No its definately not finger trouble!
Thanks for your help. I
21-03-2010 7:27 PM
Quote ... checking the security settings of the router. Am i right in thinking that if I put the routers ip address in the browser address bar, it should bring up the information. (Thats what I do with my Belkin router).
Yes that is how most routers work, and it would be helpful if you could tell us the exact model number of the router in question, so we can have a look at the settings from a downloaded handbook from the manufacturers website !
21-03-2010 7:45 PM
Quote 1. Laptop internet security firewall blocking when on HOME location profile, but not blocking when AWAY - I really don't understand this. She is using windows firewall. Do you mean that the settings change?
OK, I had assumed the laptop had something other than the Windows Firewall.
What I was referring to, was that many third party Internet Security products (such as Norton Firewall, and others) allow you to configure several "profiles" and associate these "profiles" with different networks.
So for example you might have three profiles set-up, perhaps -
"HOME" - where the firewall has strict rules for internet access, but open access for other trusted computers on the local network.
"WORK" - again strict rules for internet traffic, but moderate access for anything else.
"PUBLIC" - for use in public places (e.g. airports, or cafes). so very strict internet access, and total blocking of any other traffic.
On some of these security products, the software will detect a change of network and apply the relevant settings, on others you can change profiles manually.
Unfortunately I am unfamiliar with the capabilities of the Windows 7 firewall, but if it is anything like that on Windows XP then I don't remember it having the capability I described above, and therefore my original point is not relevant.
21-03-2010 8:00 PM
Sorry I can't check on exact model of router at the moment, but am almost certain it is a thomson 585v7 4 Port Wireless router.
I will supply you with the information as soon as I can. As things stand I think I will have to wait till next weekend to get it sorted, ( posted this now because I thought someone might have an easy solution and I could have sorted it for her whilst at my house - realise now I should have waited - sorry ) so please can you keep track of this post. I'm sure that you are going to be the answer to my prayers eventually and make an old lady very happy as well.
Thank you
21-03-2010 8:09 PM
Quote 4. Not sure about this at all, but if I am looking in the right place. Obtain ip address automatically is checked on settings in laptop. Again I can't check router settings.
On the laptop, in the place where the setting for "Obtain an IP address automatically" is, check that it is also set to "Obtain DNS server address automatically". This will ensure the network configuration for the laptop is provided by the router.
Now you need to check in the router set-up, whether the DNS settings are obtained automatically (by querying the PlusNet servers), or whether they have been manually specified (in a similar way to the Windows network settings).
Anyhow, there should be a "DSL Status" page of some sort, which should list which DNS settings the router is using. If you can record these numbers and post them here, then someone will tell you whether these are PlusNet values, or something else.
If the DNS values are PlusNet settings, then we know what you are dealing with. However there are services such as "OpenDNS" where you change the router or PC DNS values to 'point' at their servers, and from then on every request to the internet passes through their filtering system, and depending on how those filters are set, but may cause unexpected results (if you are not aware that filtering is going on !). This can be helpful in providing some level of content filtering, although in the case of YouTube, you would be totally blocked.
From what you have said, it is very unlikely that the DNS settings are a problem, but worth checking anyway even if just to completely eliminate the possibility of misconfiguration.
21-03-2010 8:21 PM
If you can get another laptop working with YouTube on YOUR home router, then take that laptop to your mother's and see whether it then works with her router.
In fact as you are setting automatic addresses, you should be able to run BOTH laptops at the same time.
If that is successful then you will have eliminated the router filtering, PlusNet filtering, any DNS issues, and would tend to point to a laptop configuration issue (although I have no idea what !)
Good luck
