sync issue and broadband tester
- sync issue and broadband tester
26-08-2008 9:28 AM
Hi
For the last week or 2 I have been seeing a drop of speed and have now noticed that after a few reboots my modem can no longer sync at 8132Kb (8MB). It varies evey reboot and currently is 7360kbps but i have seen as low as 6000. Obviously this also plays havoc with my profile as it keeps changing Your current broadband speed is 6000 Kbps
My line has always been sync at the max and I have never had an issue until now, 4+ years. Nothing has changed my end and I suspect a cable fault. This is a seperate line with no phones or extension wiring.
So i tried to use the plusnet broadband checker.
I checked my case staus this morning to see this
I return to the checker using the link and it says I have a case open and apart from the cancel button thats it. So how do I run the extra checks its mentions?
Regards
Nick
Quote `Broadband Fault Checker - Initial checks [ Completed ]
All initial checks have been completed without finding any problems. You now need to visit the Broadband Faults Checker and complete a number of detailed checks to progress your fault further. Please make sure you do this within the next 48 hours, otherwise your Question will close and your fault won't be checked anymore.`
Regards
Nick
Message 1 of 3
(874 Views)
2 REPLIES 2
Re: sync issue and broadband tester
26-08-2008 9:47 AM
I've just had a look at your account and it looks as though you've completed the fault report now and you've had a reply from our faults team. Hopefully the information they've given will help, if not simply respond to the ticket through the help area of the website and we'll pick it back up.
Message 2 of 3
(346 Views)
26-08-2008 10:13 AM
Hi
Thanks for the update. I will monitor for another week and see if i can get back my max stable rate of 8132
As currently I am taking an approx 2MB hit
BIP Interface Data
Current line rate Line rate change timestamp Maximum Stable Rate Recalcuated ProfileTimestamp Maximum Stable Rate
6000 2008-08-25T09:22:59 N 2008-08-24T10:04:00 8128
Regards
Nick
BIP Interface Data
Regards
Nick
Message 3 of 3
(346 Views)
