speed capped
- speed capped
speed capped
12-04-2014 5:12 PM
my broadband speed has decreased since my original contract to .75 Mbps. from 1.75Mbps. Have you capped my speed? This is a repeat of the cap that was there when i first joined you.
Link Information
Uptime: 0 days, 0:01:33
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4.608
Data Transferred (Sent/Received) [kB/kB]: 53,31 / 187,72
Output Power (Up/Down) [dBm]: 12,3 / 19,4
Line Attenuation (Up/Down) [dB]: 30,0 / 48,5
SN Margin (Up/Down) [dB]: 21,0 / 5,8
Chipset Vendor ID (Local/Remote): BDCM / ????
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 45 / -
FEC Errors (Up/Down): 0 / 116.231
CRC Errors (Up/Down): 0 / 106
HEC Errors (Up/Down): - / 106 / 153
Link Information
Message 1 of 8
(1,148 Views)
7 REPLIES 7
Re: speed capped
12-04-2014 5:19 PM
Can you post the rest of the information requested here please http://community.plus.net/forum/index.php/topic,96155.0.html and we might be able to see what is going on
Message 2 of 8
(766 Views)
Re: speed capped
12-04-2014 5:32 PM
Jim more info
bt wholesale test (cabled and in test socket)
download 0.53
acceptable range 0.2 - 1.0
dsl connection rate 4.96 down 0.45 up
ip profile 0.75
Current line speed 0.75
thanks
download 0.53
ip profile 0.75
thanks
Message 3 of 8
(766 Views)
Re: speed capped
12-04-2014 5:38 PM
As I feared
You are on a 20CN connection - you can check here http://usertools.plus.net/exchanges/ and it probably doesn't say this
BT have advised that this exchange is enabled for WBC on 21CN
Because of this the IP profile takes a day or so to increase after an increase in sync speed
You must have had a very low sync recently
Can you post the router stats again as I would like to see the errors
Message 4 of 8
(766 Views)
Re: speed capped
12-04-2014 5:43 PM
here you go
Link Information
Uptime: 0 days, 0:41:53
Data Transferred (Sent/Received) [MB/MB]: 24,74 / 50,74
SN Margin (Up/Down) [dB]: 21,0 / 6,0
Error Seconds (Local/Remote): 1.424 / -
FEC Errors (Up/Down): 1 / 3.495.768
CRC Errors (Up/Down): 3 / 2.790
HEC Errors (Up/Down): - / 2.790 / 4.166
thanks for your help
Link Information
Message 5 of 8
(766 Views)
Re: speed capped
12-04-2014 5:53 PM
As I thought there are far too many errors on the line
After 42 minutes connected in the test socket
When using the test socket are all the other extensions in the property dead
Assuming that they are you next step is to raise a speed fault here https://faults.plus.net
Message 6 of 8
(766 Views)
Re: speed capped
12-04-2014 6:17 PM
Jim
yes, all other extensions were disconnected. i'll raise a support ticket. thanks for your help.
Message 7 of 8
(766 Views)
Re: speed capped
14-04-2014 1:10 PM
Hi mamazoo,
I can see you've got a phone fault engineer booked in, let us know how it goes.
Message 8 of 8
(766 Views)
