i have a stupidly low connection speed.
kierang
Im a new customer and have had trouble getting a connection . after calling customer service they asked me to try the test socket and i had a connection . but having managed to do a speed check i am only getting 0.25 Mbps . its frustrating can anybody shed some light on this. is it a setting i need to change or is there a problem with the line?
Fixes: 62
Re: i have a stupidly low connection speed.
I suspect that the problem was caused when you weren't using the test socket
Can you post the information requested here http://community.plus.net/forum/index.php/topic,96155.0.html
kierang
Connection Information
Link Status: IPv4 connected
IPv6 disconnected
Uptime: 0 days, 18:27:13
Data Transferred (Sent/Received) [MB/MB]: 15.22 / 467.41
Username: <snip>
Password: ********
Remember Password: Yes
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 87.113.163.11
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
TCP/IPv6 Settings
IPv6 State: Disabled
jim:green username removed mod:end
Fixes: 62
What we need is this
This is from my connecrtion
Link Information
Uptime: 18 days, 2:07:08
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 888 / 3.854
Data Transferred (Sent/Received) [GB/GB]: 1,65 / 1,16
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 26,4 / 49,5
SN Margin (Up/Down) [dB]: 9,9 / 3,9
kierang
Link Information
Uptime: 0 days, 18:33:42
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 440 / 283
Data Transferred (Sent/Received) [MB/MB]: 19.08 / 530.90
kierang
Uptime: 0 days, 18:35:20
Data Transferred (Sent/Received) [MB/MB]: 19.11 / 530.95
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 16.4 / 30.5
SN Margin (Up/Down) [dB]: 31.9 / 25.3
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 11 / 0
FEC Errors (Up/Down): 88 / 1,737
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi kierang,
I'm sorry to hear of the issues you're having with your connection.
I've just requested the banding on your line be removed, this should bring the speeds back within the next 4 hours.
Chris Pettitt
Cloud Environments Engineer
kierang
thank you very much .  Smiley
Plusnet Staff
Plusnet Staff
Fixes: 5
That should be sorted out for you now Smiley
Chris Pettitt
kierang
all good . thanks for your help
