question re billing
- question re billing
question re billing
27-08-2011 6:27 PM
If I go just a teeny bit over my 10gb, then you top me up with another 5gb and add £5 onto the bill...what if I only use say 1 or 2 gb - does that carry over to next month ? or is it a standard charge of £5 whether I use 1 extra gb or all 5?
Message 1 of 4
(764 Views)
3 REPLIES 3
Re: question re billing
27-08-2011 6:54 PM
You lose all the surplus usage even if you only use 0.1GB
Message 2 of 4
(305 Views)
27-08-2011 8:33 PM
Quote from: ming ...what if I only use say 1 or 2 gb
Which is all I do every month. Should I qualify for a discount?
Message 3 of 4
(305 Views)
30-08-2011 4:39 PM
Guys...
If you're on Value then you can upgrade to Extra for just £5 per month and get another 50GB
Jojo
Jojo
Message 4 of 4
(305 Views)
