plus net line speed against bt speedtester ip profile
- plus net line speed against bt speedtester ip prof...
13-03-2014 9:31 AM
Does the PN line speed affect speed at all? i noticed that my bt ip profile is higher
Estimated line speed:
4Mb (This may vary between 3Mb and 7Mb) - Checked on 2014-03-07 17:22:01
Current line speed:
7.3 Mb
1. Best Effort Test: -provides background information.
Download Speed
6.89 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.89 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 8.03 Mbps
Upload Speed
0.86 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.86Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
thanks!
Current line speed:
7.3 Mb
Download Speed
6.89 Mbps
0 Mbps 7.15 Mbps
Upload Speed
0.86 Mbps
0 Mbps 0.83 Mbps
thanks!
Message 1 of 7
(1,300 Views)
6 REPLIES 6
Re: plus net line speed against bt speedtester ip profile
13-03-2014 9:32 AM
i have also had a higher download speed than (before my massive power cut last night) my ip profile and wondered if it will get any higher over time?
Message 2 of 7
(654 Views)
13-03-2014 11:50 AM
Hi davidfriedlander,
Thank you for the information you provided.
I've had a look for you and have amended your connection profile on your account to 8Mbps. Hopefully you'll start to see a slight improvement in your speed now.
Message 3 of 7
(654 Views)
13-03-2014 12:03 PM
many thanks Linn
Message 4 of 7
(654 Views)
14-03-2014 9:08 AM
due to another power cut this has happened again!
does the pn line speed increase itself automatically or does it require intervention?
Message 5 of 7
(654 Views)
14-03-2014 4:36 PM
I've given your connection profile a slight nudge which should take effect in the next 10-15 minutes. What kind of speeds are you seeing now?
Message 6 of 7
(654 Views)
18-03-2014 11:11 AM
Hi Linn,
Speeds are good and consistently higher than my current line profile and my bt ip profile:
my plusnet profile is 7.9, which i think is holding my speed back a touch, as i have stated before my previous supplier was a constant 10mbps with a download throughput of 1.1mb a sec, i have had some power cut problems recently due to a broken underground cable which is now resolved, can we squeeze a little more out of my connection?
Download Speed
7.42 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 7.42 Mbps
IP Profile for your line is - 8.06 Mbps
Upload Speed
0.83 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.83Mbps
Download Speed
7.42 Mbps
0 Mbps 7.15 Mbps
Upload Speed
0.83 Mbps
0 Mbps 0.83 Mbps
Message 7 of 7
(654 Views)
