part fibre broadband
PowerLee
Re: part fibre broadband
I use a TP Link TL-MR105 router with a iD mobile 4G sim to get a mobile broadband connection for the workshop as I cant have a fixed broadband connection installed there.
Plenty of mobile broadband solutions out there if you cant / dont want to have a normal fixed line installed.
lahbrannan1
Fixes: 4
Hi @carlhodgkinson
I have checked the database and it seems full fibre (FTTP) is available to order at your address. As we now fall under the scope as a broadband only provider we do not have the capacity to offer a landline along with the broadband nevertheless you do have the option to be transferred to EE whom are part of the same consumer group as ourselves, they would be able to offer a digital line and broadband.
Should you wish to discuss your options going forwards, I would recommend reaching out to our sales and retentions team, the contact number is 0330 1239 123
Many Thanks
Lee
Lee Brannan
mechanic123
@jab1 wrote:
@carlhodgkinson It is a small grey box (4" x 4.1/2") and totally unobtrusive.
Goes with the unobtrusive heat pump box. Probably quieter though.
