odd speed issue
- odd speed issue
odd speed issue
04-03-2014 9:25 PM
Normally between 19:00 and 22:00
Currently on 3 just to complete this, I though it was packet drops but have tested with a monitor and seems ok
When I speed test I get 20mb down and 20mb up which isn't great for fibre but it's not even getting over 500 for downloads
Does this bt test look wrong attached
Re: odd speed issue
04-03-2014 9:37 PM
Manchester here.
Re: odd speed issue
04-03-2014 9:50 PM
Sometimes I load a page and get only text no formating or pictures
Re: odd speed issue
04-03-2014 11:03 PM
It has been very slow this evening.
I have a 70Mbps line and despite the speed tests stating that there's nothing wrong with my connection, I have found many sites to load slowly or not at all.
Re: odd speed issue
04-03-2014 11:10 PM
Re: odd speed issue
04-03-2014 11:11 PM
Re: odd speed issue
04-03-2014 11:12 PM
Re: odd speed issue
04-03-2014 11:13 PM
Re: odd speed issue
05-03-2014 8:50 AM
Re: odd speed issue
05-03-2014 11:53 AM
It wasn't this morning when I tried, i also wonder if my line is right , i have posted another topic encase
Re: odd speed issue
05-03-2014 9:47 PM
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
Re: odd speed issue
05-03-2014 10:08 PM
Re: odd speed issue
06-03-2014 7:06 AM
Believe this was fixed around 1 am looking at other thread
Re: odd speed issue
06-03-2014 3:27 PM
Let us know if you notice any different though!
Re: odd speed issue
06-03-2014 3:45 PM
I don't know if this is the correct place to post, but I have been having speed issues too. From about 4pm until 12pm the service deteriorates with the speed being 0 to 3Mbs at around 8pm.I started this broadband fault issue in mid Jan. it is still unanswered. I have had two visits from Openreach engineers. I have provided speed graphs, taking a test every 15 mins, and also Tbb BQM graphs showing the problem period so obviously to technical support. According to Tbb The BQM graph pattern indicates that Plusnet are using a VP with insufficient bandwidth to enable the throughput at peak times. I am on 80/20 FTTC from the beginning of 2013.The problems started Jan 2014. Help!
