mybroadbandspeed.co.uk/
- Re: mybroadbandspeed.co.uk/
- « Previous
- 1
- 2
- Next »
08-06-2008 1:04 PM
the main prog works ok
download Speed: 6114 kbps (764.3 KB/sec ) Upload Speed: 381 kbps (47.6 KB/sec )
is it that you registered to save the results and that has run out, Cant see why you are using this as its the same as PN's mybroadbandspeed test
Message 16 of 20
(401 Views)
08-06-2008 1:49 PM
Quote from: Mav I'm currently getting the following message when I attempt to use BroadbandMax.co.uk:
It was working three days ago. Perhaps they have got fedup with people using it, who are not their customers? I quite liked it, but now I've discovered the Plusnet one is better, I wouldn't have used it much anyway.
Message 17 of 20
(401 Views)
08-06-2008 8:28 PM
Message 18 of 20
(401 Views)
09-06-2008 10:21 AM
Quote from: rockradio Hi James
Are you saying just copy the stats and keep a record myself or am I reading into your post the wrong way? ?
Rockradio
No, not at all
I was just showing how far back mine dated to on this machine.
Message 19 of 20
(401 Views)
09-06-2008 2:41 PM
Message 20 of 20
(401 Views)
- « Previous
- 1
- 2
- Next »
