major problems
- major problems
major problems
16-09-2013 12:50 AM
Hi all been on plusnet fibre since 20/8/13 and had nothing but problems, router keeps disconnecting wifi is only 1mb however ethernet is 74.00, i bought the asus rt n66u straight away had wifi at 72mb now all of a sudden wifi keeps disconnecting and i only get 1mb wireless help really needed
Message 1 of 2
(410 Views)
1 REPLY 1
Re: major problems
16-09-2013 7:48 AM
is the dropouts just on wifi or do they also happen on if you wire your connection ?
Message 2 of 2
(194 Views)
