I think I am going to turn my router off overnight - every night
- I think I am going to turn my router off overnight...
13-09-2013 10:52 AM
The result is that the line sometimes resyncs with a speed of about 3700kbps instead of just over 4Mbps
So if I disconnect the router when I retire for the night and reconnect it in the morning (using the connect/disconnect option on the router before/after unplugging the connection to the phone line) will this have any effects on the DLM system in the exchange
Re: I think I am going to turn my router off overnight - every night
13-09-2013 11:00 AM
13-09-2013 11:05 AM
I can tell when it has happened as the noise margin in the Routerstats icon shows a noise margin over over 8dB and I then do a manual resync.
This wouldn't be a problem except the Plusnet profile can sometimes pick up the low sync and then I have 3 days of slow speeds
13-09-2013 11:15 AM
Oh the joys of 20CN!
13-09-2013 11:51 AM
13-09-2013 1:14 PM
13-09-2013 1:27 PM
13-09-2013 1:35 PM
if your wires are all overhead then certainly it would point to some part of it suffering from undue degradation, I know a few people with similar problems but there all down to damaged cables (where some chimp though he could get a few bob for scrap) but not so bad as to have forced BT to replace them immediately....
15-09-2013 3:16 PM
I had a very competent engineer check the whole thing to sort out a problem with the line disconnecting occasionally when the phone rang
15-09-2013 6:30 PM
15-09-2013 7:01 PM
