low speed (again) and inscreased SNR
- Re: low speed (again) and inscreased SNR
29-07-2010 3:45 PM
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
30-07-2010 9:01 PM
![Angry Angry](/html/@8746C25E4D2FCE77DBF681B64ABA6B5A/images/emoticons/angry.gif)
Uptime: 0 days, 0:54:50
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 9,315
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 19.0 / 36.5
SN Margin (Up/Down) [dB]: 27.0 / 11.0
Loss of Framing (Local/Remote): 34 / 0
Loss of Signal (Local/Remote): 7 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 123 / 0
FEC Errors (Up/Down): NA / 2,303
CRC Errors (Up/Down): NA / 6
HEC Errors (Up/Down): 0 / 4
30-07-2010 10:22 PM
The high number of FEC (Forward Error Correction) is indicative that of errors corrected in flight by interleaving.
You seem to be lucky with the level of CRC errors but you are getting a few HEC errors which are indicative of uncorrectable errors being detected.
If you reduce your Noise Margin, you will get more errors and your line will reset more often.
You will have to check all the local wiring etc etc...
31-07-2010 10:07 AM
@OP Hope you don't mind too much to me butting in.
@ A Fox is Evil
How does one interpret the error statistics; by number:time ratio, or something else? What are acceptable rates.
31-07-2010 1:36 PM
Hard to say what counts as good/bad on a per day basis.
Most important error indication are CRC errors - I think a few hundred a day would probably count as quite high.
It depends how the errors are clustered over the time - if you get them all at once, you will probably get your line resynced [bad]!
FEC errors don't have much effect - so large numbers are OK - possibly thousands per day.
But HEC errors mean retransmissions, so anything more than small numbers are quite bad.
Have a look in Wikipedia for a technical explanation of what the abbreviations mean.
My current router doesn't give a proper breakdown by error type - but I got just 36 CRC errors over the last 12 hours.
31-07-2010 2:19 PM
Quote from: A Most important error indication are CRC errors - I think a few hundred a day would probably count as quite high.
Even on my line that sync at 8128 had l large volume CRC plus other hec etc I found fitting BT-i plate reduced them by over 95%
Puddy
31-07-2010 3:17 PM
31-07-2010 9:54 PM
![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
This a router stats graph of my line.
31-07-2010 11:37 PM
01-08-2010 1:01 PM
Unless that daily rate starts to come down, don't expect BT to reduce your noise margin.
02-08-2010 9:54 AM
BTW I seem to synching @ 6653 after needing to turn off overnight. Banded as well???
02-08-2010 12:19 PM
02-08-2010 2:37 PM
Downside is that it increases latency.
For gaming, speed isn't particularly vital - but a reasonable latency is.
09-08-2010 1:11 PM
![Cry Cry](/html/@6B4B63041062049E874E6843927E9ADE/images/emoticons/cry.gif)
10-08-2010 2:44 PM
