lost speed
- lost speed
lost speed
26-07-2013 1:34 PM
I had to disconnect from the master socket several times while new windows were fitted. I have had good speeds on my 2 meg for months but now I am down to about half a meg.
here are my router readings
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,176
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 62.0
SN Margin (Up/Down) [dB]: 13.0 / 6.5
My speed was this this morning
Today 08:42 615 kbps (76.9kB/s) 271 kbps (33.9kB/s)
download is usually 220kB/s
My sn margin is very low but my bandwidth is still very good...its been that or there abouts for ages...could this be caused because the router thought I was having connection issues and has slowed down my speed for a while, while it finds a stable connection again.
or could it be a case that my house wiring has been damaged when the workmen fitted the windows., the master socket was right next to the windows and had to be unscrewed off the wall hence the lost connection
thx for any help
Re: lost speed
26-07-2013 3:51 PM
Your BT profile had already come back up as of this morning so I've set your PN profile back to 1900 to match, hope that gets things back to how they should be
Re: lost speed
26-07-2013 6:28 PM
my latest speed check
Today 18:26 565 kbps (70.6kB/s) 378 kbps (47.3kB/s)
Worse than this morning..........will give it a week and see what it does
thx
Re: lost speed
27-07-2013 8:09 PM
Yesterday 21:19 1468 kbps (184kB/s) 380 kbps (47.5kB/s)
Yesterday 19:42 1617 kbps (202kB/s) 370 kbps (46.3kB/s)
Yesterday 18:26 565 kbps (70.6kB/s) 378 kbps (47.3kB/s)
Yesterday 08:42 615 kbps (76.9kB/s) 271 kbps (33.9kB/s)
definitely on the mend...any reason why you changed the profile to 1900 from 2178 as it was in above posts...I am still slower than I have been for last 3 or 4 months.
thx
Re: lost speed
27-07-2013 8:31 PM
Re: lost speed
29-07-2013 3:56 PM
I'm sorry to see that's dropped further since Matt changed the profile.
Quote I had to disconnect from the master socket several times while new windows were fitted
Were any permanent changes made to the socket or wiring whilst that work was being done?
Adam
Re: lost speed
30-07-2013 7:51 AM
speed over past few days
Today 07:49 1481 kbps (185kB/s) 372 kbps (46.5kB/s) Share
Yesterday 09:20 1426 kbps (178kB/s) 376 kbps (47kB/s)
Sunday 19:25 1521 kbps (190kB/s) 377 kbps (47.1kB/s)
Re: lost speed
30-07-2013 12:52 PM
Re: lost speed
30-07-2013 3:02 PM
Re: lost speed
31-07-2013 9:24 AM
Quote ..if so then maybe it should be set at that by plusnet seeing as it has run at that without any issues for months.
There'd be no point, we need to make sure the line profile is appropriate to the line speed, otherwise that will cause other issues which you don't want to have
As the synch speed is lower than you've previously experienced and given that the connection seems fairly stable at present it might be worth doing a bit of fault finding now.
For now can you get your router connected to the <a href="http://www.plus.net/support/broadband/master-socket-guide.shtml">test socket</a> or if you don't have one of those connect to the master socket and unplug any other phones or other devices connected to the line and drop me a reply as I'd like to run some line tests with things set up in that way:
Re: lost speed
01-08-2013 7:20 PM
sorry been away a few days.....Yesterday I rewired the master socket and replaced all filters. So my speed has dropped again because of the lost connections while doing it. Can someone reset my speed up to the 1900 again please, as at the moment it has dropped to 1344. Don't want to connect to the master socket just yet as it is down stairs and my computer is up stairs. I think I will get my speed back over a couple of weeks if I don't lose connection again for a while.
thx
Re: lost speed
02-08-2013 10:15 AM
It looks like there's been a few more disconnections since as per the graph.
Is this anything you were doing? There's no point in us resetting the line whilst there are disconnections taking place.
<img src="http://community.plus.net/visualradius/generated/image13754347662284.png"/>
Re: lost speed
02-08-2013 1:09 PM
Re: lost speed
02-08-2013 3:42 PM
Uptime: 0 days, 0:28:30
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,688
Output Power (Up/Down) [dBm]: 12.5 / 17.5
Line Attenuation (Up/Down) [dB]: 31.5 / 61.0
SN Margin (Up/Down) [dB]: 14.0 / 7.0
...my bandwidth now says 2688
Re: lost speed
05-08-2013 10:01 AM
