lost speed
Griff7520
lost speed
HI
I had to disconnect from the master socket several times while new windows were fitted. I have had good speeds on my 2 meg for months but now I am down to about half a meg.
here are my router readings
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,176
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 62.0
SN Margin (Up/Down) [dB]: 13.0 / 6.5
My speed was this this morning
Today 08:42 615 kbps (76.9kB/s) 271 kbps (33.9kB/s)
download is usually 220kB/s
My sn margin is very low but my bandwidth is still very good...its been that or there abouts for ages...could this be caused because the router thought I was having connection issues and has slowed down my speed for a while,  while it finds a stable connection again.
or could it be a case that my house wiring has been damaged when the workmen fitted the windows., the master socket was right next to the windows and had to be unscrewed off the wall hence the lost connection
thx for any help
16 REPLIES 16
orbrey
Re: lost speed
Hi Griff,
Your BT profile had already come back up as of this morning so I've set your PN profile back to 1900 to match, hope that gets things back to how they should be Smiley
Griff7520
Re: lost speed
Hi
my latest speed check
Today 18:26 565 kbps (70.6kB/s) 378 kbps (47.3kB/s)
Worse than this morning..........will give it a week and see what it does
thx
Griff7520
Re: lost speed
Today 19:42 1474 kbps (184kB/s) 375 kbps (46.9kB/s) Share
Yesterday 21:19 1468 kbps (184kB/s) 380 kbps (47.5kB/s)
Yesterday 19:42 1617 kbps (202kB/s) 370 kbps (46.3kB/s)
Yesterday 18:26 565 kbps (70.6kB/s) 378 kbps (47.3kB/s)
Yesterday 08:42 615 kbps (76.9kB/s) 271 kbps (33.9kB/s)
definitely on the mend...any reason why you changed the profile to 1900 from 2178 as it was in above posts...I am still slower than I have been for last 3 or 4 months.
thx
ejs
Aspiring Hero
Fixes: 25
Re: lost speed
The profile speed is 88.2% of the sync speed shown in the ADSL stats. 88.2% of 2176 = 1919.232 which is then rounded down by Plusnet.
adamwalker
Fixes: 221
Re: lost speed
@Griff7520
I'm sorry to see that's dropped further since Matt changed the profile.
Were any permanent changes made to the socket or wiring whilst that work was being done?
Adam
 Adam Walker
Griff7520
Re: lost speed
no changes made to the wiring...speed is getting better....usually takes a couple of weeks to get up to the 2 meg I was getting before.
speed over past few days
Today 07:49        1481 kbps (185kB/s) 372 kbps (46.5kB/s) Share
Yesterday 09:20  1426 kbps (178kB/s) 376 kbps (47kB/s)
Sunday 19:25      1521 kbps (190kB/s) 377 kbps (47.1kB/s)
ejs
Aspiring Hero
Fixes: 25
Re: lost speed
Your maximum download speed isn't going to change unless your ADSL sync speed changes, unless you were hoping for your Plusnet line speed to end up incorrectly set too high.
Griff7520
Re: lost speed
if you look in the first post you can see my router stats for bandwidth saying 2176....that went to that speed on its own ...I was told that the line had found its stable speed.....so I am expecting it to do the same....or are you saying that it wont do that?...if so then maybe it should be set at that by plusnet seeing as it has run at that without any issues for months.
adamwalker
Fixes: 221
Re: lost speed
Hi all,
There'd be no point, we need to make sure the line profile is appropriate to the line speed, otherwise that will cause other issues which you don't want to have Smiley
As the synch speed is lower than you've previously experienced and given that the connection seems fairly stable at present it might be worth doing a bit of fault finding now.
For now can you get your router connected to the <a href="http://www.plus.net/support/broadband/master-socket-guide.shtml">test socket</a> or if you don't have one of those connect to the master socket and unplug any other phones or other devices connected to the line and drop me a reply as I'd like to run some line tests with things set up in that way:
 Adam Walker
Griff7520
Re: lost speed
hi.
sorry been away a few days.....Yesterday I rewired the master socket and replaced all filters. So my speed has dropped again because of the lost connections while doing it. Can someone reset my speed up to the 1900 again please,  as at the moment it has dropped to 1344. Don't want to connect to the master socket just yet as it is down stairs and my computer is up stairs. I think I will get my speed back over a couple of weeks if I don't lose connection again for a while.
thx
adamwalker
Fixes: 221
Re: lost speed
It looks like there's been a few more disconnections since as per the graph.
Is this anything you were doing? There's no point in us resetting the line whilst there are disconnections taking place.
<img src="http://community.plus.net/visualradius/generated/image13754347662284.png"/>
 Adam Walker
Griff7520
Re: lost speed
yea...sorry...you can do it now....I have been messing with the extension wiring this morning and last night......I have also connected my router directly to the master socket and am connected to the internet by wireless connection....not touching anything else now....thanks
Griff7520
Re: lost speed
after connecting to the master socket I now have these readings on my router
Uptime: 0 days, 0:28:30
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,688
Output Power (Up/Down) [dBm]: 12.5 / 17.5
Line Attenuation (Up/Down) [dB]: 31.5 / 61.0
SN Margin (Up/Down) [dB]: 14.0 / 7.0
...my bandwidth now says 2688
orbrey
Re: lost speed
That's looking a lot healthier, though I'm afraid your profile on BTs side still hasn't gone above 1900 (which is where it is at present). Hopefully it'll pick up soon for you.
