looks like my fttc down
darklight1
Good morning all, my FTTC went down late last night around 11.30pm, I wasn't going to mess with it at that time so I left till this morning, what I tried is swap the router from my asus router back to the plusnet router, that didn't work, so I just tried swapping that dsl modem, didn't fix it so not sure what else I can do now can any help plzz
Using mobile data to post this.
8 REPLIES 8
Fixes: 334
Re: looks like my fttc down
@darklight1 is the ASUS a combined modem/router? Which unit do you have connected currently, and is your Plusnet unit a Hub1 or Hub2?
darklight1
Not a combined modem router, its one if the old BT openreach modems, and I have a plusnet technicolor router, but I usually use a asus rt ax58u router normally.
Fixes: 334
OK. In that case:-
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
willcutforth
Fixes: 113
Hey there @darklight1
Sorry it took a while to get back to you. Super busy in Plusnet HQ at the moment. Can you just confirm it's all resolved now after the outage?
 Will Cutforth
darklight1
All working again, it came back on 24 hours from after it went down, think it was down all of my area, thats what i was told.
Getting my full speed, 74.19 down 17.06 up, with speedtest.net
Fixes: 334
Glad to hear that. Did you try my suggestions, though - if you had, you may have got your answer earlier?
willcutforth
Fixes: 113
Awesome, glad it's back up and running. Smiley
 Will Cutforth
darklight1
No i just called plusnet found out that was.
