latency , ping and bufferbloat
darrent3
Re: latency , ping and bufferbloat
do   you have  any  idea as  to   why   my    ms  might  be so high
darrent3
image223.png78  dps and fttc
darrent3
dsp
Fixes: 380
Looking at that - I would suggest you have a fault. The best way to get it sorted is to report it via: https://www.plus.net/help/report-a-problem/
And what is this 'dsp' you keep mentioning?
darrent3
Downstream sync speed
Fixes: 380
OK. As I said, use the link in that post to report a problem - because you certainly have one.
