Can I use Hub2 with another fibre provider
whatsaname
I have been switched to a Trooli Technicolor router for full fibre (plus net not supplying in my area yet so went with trooli)
The new router doesnt reach as far around the house as the hub2 so i was thinking i could change the login details to the trooli account.  I cant see anywhere i am able to change this.
Am i able to do this or is the hub2 locked to plusnet only?
2 REPLIES 2
Fixes: 541
Re: Can I use Hub2 with another fibre provider
Its locked to Plusnet. You may be able to use it as a wireless access point
rflitcroft
Confirm that it can be used as a wireless access point. Disable DHCP.
It will flash orange, but that is remedied with some black tape!
