is this a BT cabinet? (If not, what is it?)
- Re: is this a BT cabinet? (If not, what is it?)
24-12-2011 5:28 PM
Okay guys, im aiming to make a site that has the info about all BT PCP's & FTTC/P - I went around my area a few days ago having a look at where the cabinets are.
Theres some weird ones (big ones), bigger than a standard BT PCP, but smaller BUT wider than an FTTC cab, usually come in pairs - http://g.co/maps/vcpk4
Does anyone know what they are? They were put in around 1997 (apparentley, I was only like two years old then)
And these, anyone know what these ones are?
http://g.co/maps/375kn
VM isnt avalible in the area, so I doubt their VM. No number printed on them either. There was some that were broken into, they had cables and stuff inside them, and theres some manhole cover infront of them, you can see them slap bang infront of both cabinets (green & white)
If anyone wants to know, the site im making is: http://broadbandinfo.livefix.co.uk/
Cheers; Aman.
Cheers; Aman.
Message 1 of 6
(4,805 Views)
5 REPLIES 5
24-12-2011 5:37 PM
bit of a waste of time, Google pictures are at least two years old and probably before fibre came out
the one on the left is an old BT cabinet, the one on the right is a new Fbre cabinet
you white one could be anyrhing, traffic lights etc.
Message 2 of 6
(1,442 Views)
24-12-2011 5:42 PM
in this shot the red one is a letter box, the grey one hold the letter awaiting delivery by the post man
Message 3 of 6
(1,442 Views)
24-12-2011 5:48 PM
yeah i know;
and i do know what the bt standard bt pcp cabinets look like and the big green fttc ones, i did mention this at the start - the letterbox and grey letter holding thing isnt a cabinet fixed onto the pavement/ground.
Ive changed the title of the thread now to better suit the question.
Does anyone know what they are? (Yes, they dont seem like BT ones) - Im also indicating cabinets that look like those on the site.
Message 4 of 6
(1,442 Views)
24-12-2011 6:35 PM
this is an EMI cable televsion cabinet
A Telstra roadside cabinet housing a Remote Integrated Multiplexer (RIM) and Customer Multiplexer (CMUX)., nnot sure where though
Message 5 of 6
(1,442 Views)
26-12-2011 1:26 PM
Does this help?
http://www.robertos.me.uk/html/street_cabinets_etc.html
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 6 of 6
(1,442 Views)
