ip address
- Re: ip address
ip address
03-11-2015 9:31 PM
is there a way to stop plusnet giving my broadband us ip addresses ?
this mucks up sure signal plug
Message 1 of 4
(894 Views)
3 REPLIES 3
Re: ip address
03-11-2015 9:34 PM
They aren't, see http://community.plus.net/forum/index.php/topic,130918.0.html
Message 2 of 4
(640 Views)
Re: ip address
04-11-2015 12:13 AM
Your choices are either pay a one off £5 for a static IP which (shouldn't, unless they've started using that pool for them) be an American* IP address, or log in to your router, disconnect, wait a while (5 minutes is a safe bet) and re-connect to get a different IP.
* I don't care that Plusnet bought the IP range, the addresses are still controlled by ARIN and not RIPE and are American IP addresses.
Message 3 of 4
(640 Views)
Re: ip address
04-11-2015 1:36 AM
The various databases should be updated, but if you read the thread I linked, for reporting such addresses, in detail, you'd see that some organisations are extremely slow in updating, some needing a bit of a kick.
Message 4 of 4
(640 Views)
