intermittent speed
Dudgers
intermittent speed
any help with intermittent speed please.Started a few days a  go..I have done the basics,reset etc.
5 REPLIES 5
Fixes: 384
Re: intermittent speed
What router and product (package) are you on?
Dudgers
Bt hub,plusnet broadband
Same set up for a few years.
Fixes: 384
OK. I assume the broadband is FTTC? Why a BT hub?
Without some data/information to work with, I can only suggest you follow this : https://www.plus.net/help/report-a-problem/ , although I am not 100% sure it will work with a non-PN router.
Dudgers
what does it matter if its a bt hub? its always been a bt hub. im not getting the broadband speed that is in the contract! so i cancel it?
Fixes: 384
It possibly doesn't matter - I don't know, as I indicated, but have you tried the link I posted? If you cancel without giving PN a chance to help you, you will be subject to Early Termination Charges and delays in signing up with another ISP, as well as the very real risk that the fault will follow you.
