had a few internet drops...
- Re: had a few internet drops...
18-03-2009 12:41 PM
hiya,
i've had a couple of internet drops over the last couple of days
note that only that and NOT the adsl connection which stayed up
bit similar to the tiscali issues we had a while ago...
cheers
pete
cheers
pete
Message 1 of 7
(1,330 Views)
6 REPLIES 6
18-03-2009 12:44 PM
Is this on the 21CN trial? I've been seeing something similar off of the trial. Sync stays up, but the PPP connection disappears.
Phil
Phil
Message 2 of 7
(507 Views)
18-03-2009 12:49 PM
Hi Pete,
I'm seeing a coupler of connection drops from you this morning. Is that you manually rebooting your router?
Prior to this, you were solidly connected for 2 days.
Message 3 of 7
(507 Views)
18-03-2009 6:21 PM
tis on the trial and no didn't reboot today
and yes that'll have been the drops, thought the connection had stayed...
hopefully my new ex bt router will arrive soon...
Message 4 of 7
(507 Views)
18-03-2009 6:43 PM
Get a Netgear DGN2000 , i cant praise this unit enough solid as a rock
Ex BT meaning a BT branded 2Wire unit ? if is i found this router (2700HGV) a nightmare with stability .
Message 5 of 7
(507 Views)
19-03-2009 12:20 PM
Mark - I've seen the exact opposite!
Message 6 of 7
(507 Views)
23-03-2009 6:19 PM
I suppose different lines cope differently , i had alot problem with this unit mainly the snr jumping up and down like a yoyo (hence my recent problems) , but after reading other forums about this hardware i think i may have had a duff one :P, but in saying that i still think the DGN2000 is far superior with my 54dB line
bluewhale , what firmware are you using BT or the SBC ?
Message 7 of 7
(507 Views)
