faulty download speed @ 0.250Mb
- faulty download speed @ 0.250Mb
Re: faulty download speed @ 0.250Mb
04-03-2013 2:53 PM
How far is it from your current master socket to where the phone is, both in the hall IIRC?
04-03-2013 2:54 PM
04-03-2013 3:11 PM
current stats
DSL Connection
Link Information
Uptime: 0 days, 0:07:42
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,123 / 4,771
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 21.5 / 43.5
SN Margin (Up/Down) [dB]: 7.0 / 4.5
Loss of Framing (Local/Remote): 152 / 0
Loss of Signal (Local/Remote): 38 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 128 / 0
FEC Errors (Up/Down): NA / 22,404
CRC Errors (Up/Down): NA / 4
HEC Errors (Up/Down): 0 / 3
04-03-2013 3:49 PM
If and notice I said if, BT were to fit a new NTE5a Master Socket could it be sited near your phone, so that you wouldn't have to use an extension lead, or alternatively near where you filter for your modem/router is? Bearing in mind that the cable run would have to be easy for the BT engineer from the white connector box by the front door.
I take it you prefer to have your phone in the Hall?
I'll also send you a PM.
04-03-2013 9:02 PM
04-03-2013 9:24 PM
Don't forget the Disconnect method -
Plug the filter straight into the Master socket with no cables or extensions plugged into the master socket. Plug your modem/router into the filter. You can plug your phone extension lead into the filter, there's no problem with that as long as it's not in the master socket itself.
When you've done that post up some stats.
04-03-2013 10:29 PM
05-03-2013 9:53 PM
ps plusnet contacted me to get an engineer here on thursday do these results look like its my extension thats causin the problems I would nt want to fork out 60quid because of that
DSL Connection
Link Information
Uptime: 0 days, 0:01:34
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,128 / 5,586
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 21.5 / 39.5
SN Margin (Up/Down) [dB]: 6.0 / 3.5
FEC Errors (Up/Down): 0 / 1,294
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 10 / 0
05-03-2013 11:28 PM
But never the less that speed is considerably below the range of estimated speeds for your line.
So hopefully the engineer will not only fit an NTE5a Master socket for you, but find and fix a fault. You just need to decide where you want the Master socket so you can cut out the use of extension leads. Fitting a hard wired socket for your modem/router would be the sensible option.
Post up some more stats as soon as you can, I'd like to see what they are after the modem/router has been running a bit.
06-03-2013 1:36 AM
DSL Connection
Link Information
Uptime: 0 days, 3:46:05
SN Margin (Up/Down) [dB]: 6.5 / 4.0
FEC Errors (Up/Down): NA / 180,365
CRC Errors (Up/Down): NA / 2
HEC Errors (Up/Down): 0 / 2
06-03-2013 6:59 AM
DSL Connection
Link Information
Uptime: 0 days, 9:08:38
FEC Errors (Up/Down): NA / 305,707
06-03-2013 8:11 AM
the thing I missed last last was that with this set of stats, the attenuation is lower again than it has been with any of the previous stats including those at the master socket and the mode has changed to ADSL2 instead of ADSL2+. There has to be a fault somewhere, and the speed is well below what it ought to be, especially with that 4.0dB SN Margin Down. Surprisingly though, the CRC errors are very low!!
Whether this is a bad connection on your line, or a hardware issue at the exchange or the modem/router is difficult to conclude.
You need to ensure the modem/router is in the master socket like this when the engineer comes.
I assume you will be able to be there when the engineer does come?
06-03-2013 9:08 AM
Quote from: Anotherone the thing I missed last last was that with this set of stats, the attenuation is lower again than it has been with any of the previous stats including those at the master socket and the mode has changed to ADSL2 instead of ADSL2+.
I force ADSL2 on my connection for the very reason it has a lower attenuation and generally syncs 100kbps higher - but ADSL2 rarely uses tones above 160 on my line, so the extra tones of ADSL2+ have no benefit but still contribute to the aggregate attenuation (61.8dB)
06-03-2013 9:14 AM
06-03-2013 8:21 PM
Ill be here when engineer shows
latest stats 8.14 pm router @ master socket
DSL Connection
Link Information
Uptime: 0 days, 22:24:41
FEC Errors (Up/Down): NA / 504,424
HEC Errors (Up/Down): 0 / 4
back in an hour going for a jog
