faulty download speed @ 0.250Mb
- faulty download speed @ 0.250Mb
Re: faulty download speed @ 0.250Mb
28-02-2013 9:48 PM
If your extension leads have a bell-wire in them (which is probable), then yes you are more likely to pick up outside interference, electrical interference, lightning, radio transmission - Amateur & CB etc. It can all possibly have an effect.
The incoming BT cable looks fine, goes to what seems to be a BT77A connector - fine. Cable to master socket - not sure.
That plug in 'block' in the master socket - the bit with two sockets, is there a cable coming out of the bottom of it and where does it go?
As for your plug-in extension lead, not sure. Can you post a picture of the socket on the other end?
Are you any good at DIY?
As far as the stats go, well no drop since yesterday, but as I said before, there are some errors there and there has been a dip of 2.5dB in the SNRM which will probably recover in daylight.
28-02-2013 10:05 PM
the cable at bottom goes to the phone in front hall with filter the top connection to living room,
D.I.Y Paint an stuff no problem D.I.Y on my Pc no problem but telecoms afraid of my ar$e
attachment of extension other end
bed time now see you tomorrow tnks
28-02-2013 10:36 PM
I'll have a think about a few suggestions for you, if you can post a picture of the socket and filter that the phone is connected to that will help.
01-03-2013 2:28 PM
01-03-2013 10:07 PM
01-03-2013 11:37 PM
heres more of those stats if you need them
tnx
DSL Connection
Link Information
Uptime: 0 days, 9:01:02
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,107 / 4,712
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 21.5 / 42.0
SN Margin (Up/Down) [dB]: 5.5 / 4.0
Loss of Framing (Local/Remote): 65 / 0
Loss of Signal (Local/Remote): 24 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 39 / 0
FEC Errors (Up/Down): NA / 150,253
CRC Errors (Up/Down): NA / 232
HEC Errors (Up/Down): 0 / 192
02-03-2013 12:20 AM
Because the error count isn't too high I'm guessing it's all down to bell-wires in these extension leads. The real difficulty in dealing with this in the best way is that you don't have a modern NTE5a Master Socket (the one on the left). We could do with knowing the Fault Threshold Rate for your line, there may be a crafty way of getting this resolved, if one of the Plusnet team can help out.
02-03-2013 2:41 PM
02-03-2013 2:59 PM
02-03-2013 5:15 PM
04-03-2013 10:01 AM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13623911407283.png"/>
04-03-2013 2:20 PM
Hi doncoyle,
Your extension lead that currently goes from the master socket to where you have the modem/router, is there any spare length on it, if so, roughly how much?
04-03-2013 2:23 PM
we ll see how that fairs out
new stats with new flat lead
DSL Connection
Link Information
Uptime: 0 days, 0:15:41
Bandwidth (Up/Down) [kbps/kbps]: 1,124 / 5,088
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 23.5 / 45.5
SN Margin (Up/Down) [dB]: 6.0 / 4.5
Loss of Framing (Local/Remote): 140 / 0
Loss of Signal (Local/Remote): 37 / 0
Error Seconds (Local/Remote): 119 / 0
FEC Errors (Up/Down): 0 / 29,804
CRC Errors (Up/Down): 0 / 8
HEC Errors (Up/Down): 0 / 6
04-03-2013 2:34 PM
It doesn't matter about a shorter lead, I had another reason for asking. But Please use the Disconnect method and go back to your other lead at least an hour well before sunset.
04-03-2013 2:42 PM
