extra GB
- Re: extra GB
extra GB
02-08-2007 2:33 PM
I understand it is possible to purchase an extra 1GB for 75P a month.
Currently on 1GB (nearly used). How do I do this.
Thank you
Thank you
We are born into history and history is born into us.
Message 1 of 4
(2,749 Views)
3 REPLIES 3
Re: extra GB
02-08-2007 2:36 PM
You should be able to add more usage by following this link:
https://portal.plus.net/upgrade_process.html?do_quick_pick=1
Message 2 of 4
(886 Views)
Re: extra GB
02-08-2007 8:35 PM
sorry this does not cover what I want unless I have misunderstood something. I do not want to change my current broadband package, the link you directed me to gives me this option but what I want to do is purchase 1GB.
Your main page says"extra usage is 75p per GB if you add it up front", so the question is how do I add this 1GB as my current limit of 1GB has nearly reached its limit.
Thank you
Thank you
Message 3 of 4
(886 Views)
Re: extra GB
02-08-2007 8:41 PM
Sorry, that link is perhaps a little misleading.
This one should do it for you : https://portal.plus.net/products/upgrade/change_data_transfer.html
Message 4 of 4
(886 Views)
