didn't get a new router when I renewed contract - but now old one isn't working
TheLavingtons
Hi
We renewed our fibre contract back in the spring, but when we did, we didn't get a new router (we've been with PlusNet for a long time) - at the time we didn't need it, the old router seemed to be working ok... but recently it keeps dropping out, for no reason.  Tried to find info on the PlusNet site as to how we can ask for a replacement, but no luck. Anyone have any idea who I can contact?
10 REPLIES 10
Fixes: 334
Re: didn't get a new router when I renewed contract - but now old one isn't working
@TheLavingtons Is it the Hub which is at fault - which one, BTW? or your actual connection which is to blame.
If you need a replacement, the best thing to do is ring PN.
TheLavingtons
Did try to get in touch via website and Chat - but that just sent me round in circles and they wouldn't connect me with someone in customer services. As the internet keeps disconnecting throughout the day (and the phone line is fine) I'm assuming it's the router.
Fixes: 334
Chat doesn't work, and how 'via the website'? If the internet connection is failing, that is more likely to be the BT/OR network rather than the router - which one - Hub1/Hub2 or A.N. Other?
willcutforth
Fixes: 113
@jab1 Line is testing fine from our side, no issues.
 Will Cutforth
Fixes: 334
Thanks, @willcutforth  - I assume you mean the phone line? What about the data side? - although we really need more information from the OP before making assumptions.
willcutforth
Fixes: 113
Phone line and the speed is way above the MGS as well with it being 27Mb no errors or anything.
 Will Cutforth
Fixes: 334
OK, @willcutforth , thanks. We'll see if the OP comes back.
TheLavingtons
It's a hub one router. The biggest problem is it's intermittent, and doesn't seem to apply to any specific time
TheLavingtons
sorry - should also add, we have tried resetting the router a few times, but that just fixes it for a short while, then the internet connection starts dropping out again. Never used to be a problem - now it happens at least a few times a day
Fixes: 334
OK. You might think this is overkill, but it will give us a starting point:
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
