continued service with fibre only?
FIXEDTopic Options
- Re: continued service with fibre only?
11-03-2024 8:40 AM
If i switch to fibre only (no landline) will there be a break in service during the switch?
is there any installation/change required, or will it just carry on as usual with no disruption?
many thanks
Fixed! Go to the fix.
Message 1 of 3
(821 Views)
2 REPLIES 2
11-03-2024 8:47 AM
@jethro247 There should be no break in service that you would notice - these changes are 'flick a switch' tyes of changes, although if you were online in the small hours, you may experience a short break.
There is no 'installation' required.
11-03-2024 8:49 AM
thank you!
Message 3 of 3
(812 Views)
